1st March February 2012
Latest post 10-25-2007 4:47 PM by Santiago. 17 replies.
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Re: Set top box controller with the Beo-5!!
You can change channels on Satellite for any STB. The bottomline is if you can do something, anything with a Beo4, then you can do it with the Beo5 if correctly programmed. If you need to do several key strokes on the Beo4 to achieve an action, that same command can be done with one button click on the Beo5
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Dashing off to work now. Maybe I can help you this evening. Andy T.
Karel Uyttendaele
- Joined on 05-19-2007
- Aalst, Belgium
- Posts 682
With my STB I was (with the Beo4) able to zap up/down channel with the combination <GO> + <UP> or <GO + <DOWN>.. But it seems that the UP/DOWN function is somewhat hardcoded in the Beo5... anyone else had the same problem?
The race for quality has no finish line- so technically, it's more like a death march.
Keith Saunders
- Posts 3,810
First I have to say that the bottom "Hard keys" are programmable by your dealer as well as the screen icons, however most dealers so far appear not to touch them and with good reason because of the considerable combinations using the arrow keys alone its easy to make a mistake. But the bottomline is that ANYTHING you can do with a BEO4 with one or more key strokes can be achieved with just one key stroke on the Beo5 using a macro. I would suggest that you do NOT have the so called "Hard Keys" changed , but you get your dealer to add an UP/Down button on the "Scene" screen for your STB using the following IR macro commands:- First command is GOTO Second command is STEP_UP or STEP_DW
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
My beo5 is setup to send Go + UP and down on the hard key's works all most fine. it only works in sub folders under DTV.. Command used on mine PLAY + step_up
Chris
- Joined on 04-17-2007
- Bredene near Ostend-Belgium
- Posts 143
I was planning to visit my dealer today to take a look at this little new gadget. I know myself very well (so as my dealer), but after reading all the threats I better wait a bit longer, till all bugs are gone from the Beo5. I better go for a this afternoon.
Yes, I kown my spelling is horrible…
Mr10Percent
- In Transit
- Posts 441
Having just spent the weekend delving into the mystries of the Beo5 configuration tool, I can see that the Beo5 is going to cause lots of headaches for dealers. The software is a little idyosyncratic. The "foot-fall" effect B&O want in dealers shops will become a long queue as more and more people want ever more complex macros and the fact that a GBP400 remote just has to operate and look perfect. The macros which can be assigned to the Beo5 are essentially "step-up", "step-down", "go/play", "stop/pause/exit" anyway. The coloured buttons are on the same basis. however, I can see real issues when dealers try to program customers macros - especailly on link or AV applications. True, the Beo5 can do all that a Beo4 can do but because the Beo4 is "locked" and tested to death, it works or at least works when we program it with out finger inputs. The Beo5 will be programmed to a strict macro. A great remote but probably too flexible for its own good. 10%
Santiago
- Switzerland
- Posts 3,286
Santiago:
Please, does someone can help me with this issue? any ideas... a hint ? For info: the HDR2 is connected to the avantDVD via "VTAPE" scart. Thanks in advance.
Gerd
- Joined on 04-20-2007
- Germany
- Posts 523
It's not a bug, it's a feature! According to the user manual you have to press green or yellow in order to RW or FF.
Santiago
- Switzerland
- Posts 3,286
Gerd: It's not a bug, it's a feature! According to the user manual you have to press green or yellow in order to RW or FF.
Hi Gerd, I know it, but I'm not talking about that. Also the BS9000 works exactly in the same way, using the yellow and green keys for FF and RW, but I've asigned those "command colors" to the >> and << beo5 hard keys, if you know what I mean
Gerd
- Germany
- Posts 523
OK, I understand. Maybe because HDR2 is a OEM product, not B&O genuine? What's the actual IR command for those keys now?
Santiago
- Switzerland
- Posts 3,286
Gerd: Maybe because HDR2 is a OEM product, not B&O genuine? What's the actual IR command for those keys now?
HDR2 is a genuine B&O product. The IR commands now are : "0:000:VTR:CNTL_WIND" & "0:000:VTR:CNTL_REWIND" and when I use the commands "0:000:VTR:WIND" & "0:000:VTR:REWIND" I get the same result :"next" and "previous" recordings
but never "Wind" and "Rewind" I think the problem is clearly located in the hard keys Beo5 "re-configuration".
Page 1 of 1 (18 items)
