Latest post 10-22-2007 8:14 PM by a11mcr. 7 replies.
Page 1 of 1 (8 items)
  • 10-14-2007 12:18 PM
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Penta Mk 3 Display and Stand By
    Does anyone know why a Penta III sometimes shows the display (one speaker only - the other one works all the time!) and powers off )ie red light on) and other times does not (ie green light still on)?  Leads and output (from a BM 7000)  have been swapped to check it is not those at fault.
    I am wondering if it is in the speaker itself and if so how can one approach a fix?
     Thanks for any help....
  • 10-14-2007 1:36 PM In reply to
    Re: Penta Mk 3 Display and Stand By
    I suggest that you contact Tim Jarmam at www.beocentral.com who will be able to fix them for sure. He's not far from you in Farnborough.
    Regards Graham
  • 10-14-2007 3:30 PM In reply to
    Are you running them from speakerlink or powerlink?
    Are they set to Auto ... or L and R ?
    Neil
  • 10-15-2007 4:11 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    In response to your query
    Powerlink
    and
    L and R rather than auto
  • 10-16-2007 9:47 AM In reply to
    Hmmm ... definitely in need of a look at then!
    Neil
  • 10-16-2007 3:26 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Display issue partially resolved.  I tried another powerlink lead and that enabled the display to work!  I have tested the existing leads with a mulitmeter and each pin shows a complete circuit, but 1 out of my 3 leads does not work!  Does anyone know which of the 8 pins carries the display information so I can double check that particular pin?
    With regard to the switching to stand by, I can hear the relay attempting to switch the unit off - is that likley to be a sticking relay which I could clean or ???
  • 10-22-2007 6:22 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    The data display information is carried on the shield.
  • 10-22-2007 8:14 PM In reply to
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    Hi, pins 6 & 7 carry the display data check out the link for diagrams.
    http://www.beoworld.org/beotech/wiring2.htm
    Regards
    Mark
    Kind Regards, Mark
