Display issue partially resolved. I tried another powerlink lead and that enabled the display to work! I have tested the existing leads with a mulitmeter and each pin shows a complete circuit, but 1 out of my 3 leads does not work! Does anyone know which of the 8 pins carries the display information so I can double check that particular pin?
With regard to the switching to stand by, I can hear the relay attempting to switch the unit off - is that likley to be a sticking relay which I could clean or ???
