I guess the Beosystem and MX are too far apart for a direct connection and then split?
Anyway, below is the B&O recommended setup:
************************* VIDEO SYSTEM SETUP
Beovision MX 7000 IT
Connection Video
Connect the aerial to the aerial input of the TV-set.
Selecting option on the TV-set
Option: OPTION 1 (Factory setting), with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
1 | Observe confirmation
| from BeoVision
When using the remote control mute function, sound is
restored by
turning the volume up or down.
************************* AUDIO SYSTEM SETUP
Beosystem 6500
Beovox passive
Connection Audio
Connect the Beovox to the SPEAKERS 1 socket on the audio
master
using a loudspeaker cable.
Connect the aerial to the aerial input of the audio master.
Selecting option on the audio master
Option: OPTION 1
Press: STAND-BY SOUND 1 STORE
Press: | Display:
GO | V.OPT
LIST | A.OPT
| from AudioMaster
Note!
The Beomaster 6500 must be equipped with software (S/W) 1.4 or
higher, part no. 8341309, to enable the following operations:
- fine
tuning using the MCP 6500 (press GOTO, << or >> ),
- programming
of the Beomaster to switch to stand-by at a specific
time.
********************* AUDIO/VIDEO/LINK SYSTEM SETUP
To obtain Link intergration the main room must be equipped with a
Beolink Converter, part No. 1161166
BeoLink Converter, part No. 1161466
will not work
Connection
Connect the AUX/TV socket of the audio master to the AUDIO
AUX LINK
socket of the TV-set using a 7/7-pin DIN cable.
Connect the BeoLink Converter to the TV and audiomaster
using a 7/7-pin
DIN cable and a T-connector part No. 6270702
Note!
All Timer PLAY programming must be made on the radio.
Set Timer
ON/OFF to ON on the products to be switched on via the
Timer programming.
It is not possible to use the timer function for programming
VIDEO PLAY
or VIDEO STAND-BY.
********************* REMOTE CONTROL FOR MAIN ROOM
The recommended remote control is Beo4
The following remote controls may also be used:
Beolink 7000 (1-way IR
setup for the Video system)
Beolink 5000 (1-way IR setup for the Video
system)
Beolink 1000
However, there may be functional limitations if the alternative remote
control is used
Setup for Beo4 remote control:
Beo4's "LIST" must contain the following items in order to be able
to
operate the Main Room products.
LARGE REVEAL INDEX UDDATE MIX SUBCODE STORE
MONO (changed to SOUND
with S/W 4.0 or higher in Beo4)
TURN RETURN
(RESET)
A.SETUP (only with
S/W 2.0 or higher in Beo4)
AV (only with S/W 4.0 or higher in
Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
Note!
Beo4 must be equipped with software (S/W) 2.0 or higher to
operate:
Setup and tuning functions on the Videomaster.
The software
version can be read on the Beo4 display by
pressing (STANDBY LIST) and then
(MENU GO) at the same time.
Order No. 8001827
At battery replacement or battery failure of Beolink 5000, the
remote
control must be set to 1-way mode again. Other wise it will
not be possible
to operate the Video- or Audiomaster.
*************************** LINK SYSTEM SETUP
Master Link
BeoLab 3500 (LCS 9000)
Connection
Connect the Master Link cable to the Master Link socket on the
BeoLink Converter in the central room.
Connect the Master Link cable to the Master Link socket of
BeoLab 3500.
Connect BeoLab 3500 to the mains.
Setting of option in the Link room
BeoLab 3500:
Option 6, with Beo4
Press: | Display:
same time | OPTION?
GO | V.OPT
LIST | A.OPT
LIST | L.OPT
6 | Observe confirmation
| from the Link Product
Note!
The audio master in the main room cannot distribute PC sources,
e.g.
N.MUSIC and N.RADIO to the Master Link system.
The PC sources are
therefore only local sources in this Link room
If LCS 9000 is equipped with S/W 1.0, the Master Link setup must be
made on the product itself. This is done in the following way:
Press: STAND-BY MENU 09 PLAY Display reads out: ML OFF
Press: STEP UP Display reads out: ML ON
Press: STORE
Disconnects
mains
Connect mains
Press: STAND-BY LINK 6
STORE
If LCS 9000 has a series number lower than 10552474, pins 4 and 12
must
be short-circuited in the ML socket on LCS 9000. See also
Technical
Information 160X-2
When the stand-by function is activated in the Link room, the
audio
master in the Main room will always go on stand-by.
********************* REMOTE CONTROL FOR LINK ROOM
Beolink 1000
Setup for Beo4 remote controle:
Beo4's "LIST" must contain the following items to be able
to operate
the products from the Link Room.
CLOCK
MONO (changed to SOUND with S/W 4.0 or higher in Beo4)
TURN
RETURN
(RESET)
A.SETUP (only with S/W 2.0 or higher in Beo4)
AV
(only with S/W 4.0 or higher in Beo4)
