hi,
would be grateful for any advice, have a 28" flatscreen avant which has just started to show thin horizontal lines across the screen, i think the lines are about an inch apart and they go all the way down the screen, sometimes you can hardly see them but other times (against a plain black background for example) they're very noticeable, i think the brightness/contrast may also be fluctuating when they're visible - does anybody know what this is likely to be?, e.g tube or power supply etc ?
thanks in advance
steve
