Latest post 04-20-2007 4:00 PM by joeyboygolf. 6 replies.
Page 1 of 1 (7 items)
  • 04-20-2007 1:39 AM
    HELP! Beocenter 9000 CD Door won't open
    Hi all
    Fabulous to find this great forum.  I just moved to California and had my beautiful Beocenter 9000 and Penta towers shipped from Canada in the original crates.  Everything works fine but the CD door won't open when you press Load.  It tries and opens about 1/16" and then just hums.
    Does anyone know how to manually unlatch the CD door or is there a diagram on how I can open the system up to see what is blocking the door?
    Thanks for any help you can give me.  I love this system and have had it since 1990!
    Sid
  • 04-20-2007 2:02 AM In reply to
    Re: HELP! Beocenter 9000 CD Door won't open
    Under the front lip of the unit, in the vicinity of the door is a hole. You can use a screwdriver through the hole to manually drive the door through it's sequence from closed to open and back again to closed.
    There is a diagram in the service manual together with full details on how to open the machine for service. The service manual is available to gold members of this forum.
    Regards Graham
  • 04-20-2007 3:02 AM In reply to
    Thanks a million.  I will look for a service manual.
  • 04-20-2007 12:21 PM In reply to
    That did not seem to do anything.  I think I need to open the case and check to see if it is jammed.  I have a service manual but cannot seem to figure out how to open the system to service it.  Does anyone know which screws to take out to flip the top open on the Beocenter 9000 for service?
    Thanks.
  • 04-20-2007 1:17 PM In reply to
    There are 8 - the 3 at the front and 6 on the top at the back once you have moved the grille - if you have the sevice manual they are pointed out - section 6-1 in the 9500 manual.
  • 04-20-2007 3:27 PM In reply to
    Got it - Thanks.  Is it difficult to remove the grill??  Any magic to it?
    Appreciate your help.
  • 04-20-2007 4:00 PM In reply to
    One screw under the lift up flap and slide the grille to the right.
    Regards Graham
