Example - This is hard to grasp. You need to speak with Lutron.
Light 1 2 3 Set for 3 different light scenes
Light 4 5 6 Set for 3 different blind settings
Light 7 8 9 Set for 3 different combination settings
Light 0 set to all on
red dot all off.
So if 1 is day 2 is evening and 3 is night for lights then 4 would be day blind settings and 7 would do both.
Alternatley if the the blind motors handle Tilt then 7 is open 8 Tilt and 9 close.
Clear as mud?
beoaus.
