Latest post 09-29-2010 5:43 PM by Opman. 12 replies.
Page 1 of 1 (13 items)
  • 09-30-2007 2:20 PM
    Motorized Curtains and Beo5 integration
    Can we integrate a motorized curtain with the Beo5? If yes, how?
  • 09-30-2007 2:38 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Motorized Curtains and Beo5 integration
    Should be possible, as long as the motorized curtains are controlled with an Infra-Red remote...
     Weekly top artists:
  • 09-30-2007 3:26 PM In reply to
    Yes, the curtain is equipped with its own remote. But how to do that? can the Beo 5 operate non B&O equipment?
  • 09-30-2007 4:43 PM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    The remote codes for the curtains will be different from B&O codes and at present the beo 5 cant use other frequencies.
    I have the same problem. The only way out is to use lutron for B&O  - which uses B&O codes and operate curtains via that- its an expensive solution!
  • 09-30-2007 5:09 PM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    What about an IR-converter like the Lintronic-box -238. It works with Beo 4 and Beo 5.
    For more information: www.lintronic.dk.
    Regards Stefan
  • 09-30-2007 5:38 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    At the moment, non Beo IRs are not listed but I can assure you that they are on the way!
    Andy T.
    Poor me, never win owt!
  • 09-30-2007 5:54 PM In reply to
    I went through the Lintronic website. It can solve the problem but can I get a brief about how to do that through lutron?
    What mode to press on the Beo 4 for instance to activate the curtain? For the moment I have a lutron panel so suffice it to press the "lighting mode" to be able to control the light. What would be the case with the curtains?
  • 10-02-2007 7:38 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Melbourne, Australia
    • Posts 445
    Example - This is hard to grasp.  You need to speak with Lutron.
    Light 1 2 3 Set for 3 different light scenes
    Light 4 5 6 Set for 3 different blind settings
    Light 7 8 9 Set for 3 different combination settings
    Light 0 set to all on
    red dot all off.
    So if 1 is day 2 is evening and 3 is night for lights then 4 would be day blind settings and 7 would do both.
    Alternatley if the the blind motors handle Tilt then 7 is open 8 Tilt and 9 close.
    Clear as mud?
    beoaus.
  • 10-02-2007 7:46 AM In reply to
    • beoaus
    • Posts 445
    Or...cont...
    You need a GRX-AV (contact closure output for blinds). So using say a GBO-3104 (4 zone controller). 4 outputs can be assigned in groups of 4 1-4, 5-8, 9-12 and 13-16.  Scene 13 is the maximum for Light on the Beo4 remote.
    Speak to Lutron direct.
    Clearer than mud now.
    Beoaus.
  • 10-02-2007 7:51 AM In reply to
    • beoaus
    • Posts 445
    Some parts to help also...
    GRAFIK EYE MAIN UNITS - PLASTIC FINISH
    GBO-3103-T-CE  3 zone control 800W/channel. 10A total - 2300 W total
    GBO-3104-T-CE  4 zone control 800W/channel. 10A total - 2300 W total
    GBO-3106-T-CE  6 zone control 800W/channel. 10A total - 2300 W total
    COLOUR OPTIONS:  White (WH) Beige (BE) Ivory (IV)  Grey (GR) Bown (BR) Black (BL)
    GRAFIK EYE MAIN UNITS - SATIN NICKEL FINISH
    GBO-3103-T-CE-SN  3 zone control 800W/channel. 10A total - 2300 W total
    GBO-3104-T-CE-SN  4 zone control 800W/channel. 10A total - 2300 W total
    GBO-3106-T-CE-SN  6 zone control 800W/channel. 10A total - 2300 W total
    GRAFIK EYE ACCESSORIES
    NTGBO-4S  4 scene activator, plastic finish. Has raise/lower and off button
    NTGBO-4S-NI-SN  4 scene activator in satin nickel. Has raise/lower and off button
    NTGBO-4S-IR  4 scene activator, plastic finish. Has IR receiver and off button (no raise/lower)
    NTGBO-4S-IR-NI-SN  4 scene activator in satin nickel Has IR receiver and off button (no raise/lower)
    NTGBO-ML  Master link wall plate in plastic
    NTGBO-PL  Power link wall plate in plastic
    GBO-RS232  RS232 link. Manufactured specially for the Avarte system.
    GRX-AV  Provides two way interface between Grafik Eye and contact closure devices.  5 inputs/5 outputs.
    NGRX-PB-CE-WH  Power booster. Increases any single zone to 1800 W.
    GRX-TVI  Ten volt interface. Allows dimming of fluorescent lighting.
    beoaus.
  • 10-02-2007 7:57 AM In reply to
    Sebastien:
    Yuo can do this easy if you have BV7 or BV9
  • 09-29-2010 12:14 PM In reply to
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    I Have a BV7 Mk3 , how do you integrate curtains ?
  • 09-29-2010 5:43 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    May I direct you to the bottom of the page?
    Keith is an absolute whizz with this sort of stuff. He once told me that around 95% off all remotes available in the UK can be programmed into the Beo5.
    Dealers doing it by the book can only access what is already in the Configuration tool. If you can live without your curtain remote control for a few days, Keith can extract the ir codes and create an XML code which can be added to the Configuration tool.
    Regards
    Opman
