Latest post 09-29-2007 2:10 PM by Jandyt. 9 replies.
Page 1 of 1 (10 items)
  • 09-29-2007 12:35 PM
    Beo5 - "Lighting Button"
    after I got the new Beo 5 remote I noticed that the "Lighting Button" is not available anymore.
    My old Beo4 is equipped with such button which allows me to dim the light up and down and have up to 8 lighting scenes.
    Anybody can help how to solve this problem?
    S. Fray
  • 09-29-2007 12:53 PM In reply to
    Re: Beo5 - "Lighting Button"
    It does have a Light button unless your dealer has deleted or hidden it. Anyway if your dealer has deleted it he can re-create it or make it visible
    Regards Keith....
  • 09-29-2007 12:58 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Sebastien.
    A 'Light' button must be added when you have your Beo5 set up by your dealer.
    I switched mine back to default settings quite expecting 'Light to be there but it isn't supprisingly.
    Have you had your dealer customise it for you?
    Andy T.
    Poor me, never win owt!
    the Light button is visible "normally" after you press the button in the lower right corner where you also can choose the zones. But it is possible to place it anywhere. Not tried it yet but if your dealer didn't add a LC2 device i think it is also not visible.
  • 09-29-2007 1:10 PM In reply to
    Actually I got the Beo5 with its standard configuration ( TV, DVD, CD, Radio buttons only).
    I still have to send it back to the dealer to make the necessary update.
    My dimming system is made by Lutron.
    S. Fray
  • 09-29-2007 1:17 PM In reply to
    • Jandyt
    • Posts 13,004
    Before you send it or take it to your dealer, I seriously recommend that you make an extensive plan of what you want adding to it.
    You don't want to be running back and fore to your dealer's every two minutes!
    Andy T.
  • 09-29-2007 1:24 PM In reply to
    U r right Andy.
    It's a big headache having to do the programming at the dealer's showroom rather than doing it at home. The main problem would be for the logos of the satellite TV channels which change from time to time.
  • 09-29-2007 1:39 PM In reply to
    • Jandyt
    • Posts 13,004
    The file with TV and Satellite logos is quite extensive and is unlikely to be a problem, however, as Peter and Keith mentioned in other posts, the local radio station logos are a bit lacking.
    If you are computer literate, it might be a good idea to google your local stations, find their logos and using 'Paint' or something similar to make them into Bitmaps of the right size. Whack them onto a CD and take it to your dealer, he should then be able to add them to your configuration.
    Andy T.
  • 09-29-2007 1:46 PM In reply to
    I am using a nice website to pick up the TV logos.
    (www.lyngsat.com)
  • 09-29-2007 2:10 PM In reply to
    • Jandyt
    • Posts 13,004
    Laughing
    I used to use that site when I had a motorised Sat dish on analogue on my LX4500!
