Latest post 09-29-2007 9:01 AM by Stars. 7 replies.
Page 1 of 1 (8 items)
  • 09-28-2007 1:36 PM
    So what have I done wrong?
    I have a BC2300 in the same room as a BV6-26. The two 8000's are connected to the BV6-26. Till today all was fine I could hit CD and get CD -- I could hit radio and get radio and now nothing happens! I can get DTV and TV and DVD -- But Aggghhh there is the change. Today I have connected a DVD1 to this system. I can assure you that nothing else has changed and I get no response from either radio or cd in the main room but they work in the link rooms. I cannot get DVD sound in the link rooms. I know I know V-opt & A-opt -- I have re-set these and they are set to 1. Any ideas?
    Many thanks in anticipation. I know the CD is not so critical now I have the DVD but the radio is very critical. Running on DTV 704 as a short term solution bu thats not the answer!
    Barry BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
  • 09-28-2007 1:44 PM In reply to
    Re: So what have I done wrong?
    BarryAndrew:
    II know I know V-opt & A-opt -- I have re-set these and they are set to 1. Any ideas?
    In your configuration it should be V.opt 2 and A.opt 0.
    Good luck
    Marcus
  • 09-28-2007 1:50 PM In reply to
    I agree with Marcus
    Regards Graham
  • 09-28-2007 1:57 PM In reply to
    Tried that but no response. Can still get radio in the link rooms but not in the main room.
  • 09-28-2007 2:11 PM In reply to
    Sorry about that-- Had unplugged something this afternoon and had forgotten. However didn't know about the Vopt2 Aopt 0  so thanks very much.
  • 09-28-2007 2:32 PM In reply to
    Barry, you ASSURED us nothing else had been changed! LaughingLaughing
  • 09-29-2007 3:45 AM In reply to
    Henry,
    I know -- I am 60 this year and some of the brain cells are just beginning to die of exhaustion after years of struggling with some of B&O's internal machinations!
    Thanks to all
  • 09-29-2007 9:01 AM In reply to
    Not to worry pal Yes -  thumbs up
    Enjoy your weekend!
