I have a BC2300 in the same room as a BV6-26. The two 8000's are connected to the BV6-26. Till today all was fine I could hit CD and get CD -- I could hit radio and get radio and now nothing happens! I can get DTV and TV and DVD -- But Aggghhh there is the change. Today I have connected a DVD1 to this system. I can assure you that nothing else has changed and I get no response from either radio or cd in the main room but they work in the link rooms. I cannot get DVD sound in the link rooms. I know I know V-opt & A-opt -- I have re-set these and they are set to 1. Any ideas?
Many thanks in anticipation. I know the CD is not so critical now I have the DVD but the radio is very critical. Running on DTV 704 as a short term solution bu thats not the answer!
Barry
BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
