1st March February 2012
Latest post 09-30-2007 2:43 AM by henrik. 15 replies.
09-28-2007 7:26 AM
deaddruid
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.36.02/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 05-24-2007
- Malvern, Worcestershire
- Posts 247
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Beovision MX4000 or MX4002
Can someone explain the difference between the MX4000 and the MX4002? The website says: Beovision MX 4002 was the Beolink® variation of the MX 4000 Why would I choose one, rather than the other?
Mark
Kim.t
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 04-17-2007
- Posts 18
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Re: Beovision MX4000 or MX4002
Main diff is age and the fact that you can remote control an Avant/DVD/VCR in the main room if the MX4002 is connected with the Avant through RF- out on the Avant. You can still listen to music in the MX4000 if it is connected to a MCL2AV
BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600
deaddruid
- Posts 247
So does that mean that the 4002 is superior to the 4000, or does the 4000 have an advantage in some other area? Mark
deaddruid
- Posts 247
Um...
There were two questions in that sentence. Which one is "no"?
Mark
joeyboygolf
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.69/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
There seems to be some confusion here! The 4002 is a later version of the 4000. The difference is that the 4002 has MASTERLINK
Dave
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.88/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Brisbane, Australia
- Posts 2,328
Oh i was gonna say, go for the 4200, it has a flat screen was similar to the BeoVision 1
Beomaster
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.30.74/avatar.jpg)
- Joined on 05-02-2007
- Posts 21
Hi!MX 4002 was the Beolink Version of the MX 4000. It was designed as a Link-Room-TV. They have a Masterlink (ML) connection built in. The MX 4000 was designed as a Main-Room (but can`t work as a master like the Avant or AV9000) or stand-alone TV. As an option you can fit it with an Satellite-modul! That`s not possible with the 4002!!! You can use the 4000 for a Link-Room, too. All you need is an Datalink-Masterlink converter. So, if you are looking for a link-Tv choose the 4002. But if you need a satellite-modul it`s better to choose the 4000Sat with a converter!As a Main-Tv or stand-alone Version only a 4000 or 4200 (latest version of the 4000Series) will be the correct choise!GreetsChris
deaddruid
- Posts 247
Thank you each for your help. Two follow-on questions, though. - Is there a list of these add-on modules, such as the satellite module, somewhere on the beoworld site? I would love to see a matrix of TV models vs modules, and details on the modules.
- Is the satellite module designed for reception of analogue or digital signals?
Thank you, Mark
Keith Saunders
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.92/avatar.jpg)
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Mark, I think Beomaster really answered your first question, but I will state it in a different way:- - The MX4000 can have an Beosat LM fitted and that is the only option as far as I am aware.
- The Beosat LM is for analogue reception.
- The MX4000 has datalink and the MX4002 has Masterlink
deaddruid
- Posts 247
Thank you Keith. I'm afraid that I still have difficulty working out what can go into what. I guess this is a natural consequence of a supplier where we are supposed to rely on them to sort it out. This is fine for new equipment, but confusing when collecting electronic antiques. Mark
Keith Saunders
- Posts 3,810
Mark, As Graham said the MX4002 is a later product than the MX4000 The MX4002 has Masterlink meaning it is compatible (i.e. the same as Masterlink today) on current B&O products. Because it is a link product there was no requirement for such extras as a satellite module actually in the TV itself. If you wanted to view satellite on your MX4002 you would connect the MASTERLINK to a master video device such as an AVANT which could have a satellite module fitted in it and those satellite programmes can be called up in the on your MX4002 in the link room
deaddruid
- Posts 247
That's very clear now. Thank you, Keith.
Mark
henrik
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.77/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Stockholm, Sweden
- Posts 299
Keith Saunders:Mark, As Graham said the MX4002 is a later product than the MX4000
Yes, but they were sold side by side for approx eigth years - so a 2nd hand 4002 could in theory be up to eight years older than a 2nd hand 4000.
Page 1 of 1 (16 items)
