Latest post 09-30-2007 2:43 AM by henrik. 15 replies.
Page 1 of 1 (16 items)
  • 09-28-2007 7:26 AM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Beovision MX4000 or MX4002
    Can someone explain the difference between the MX4000 and the MX4002? The website says:
      Beovision MX 4002 was the Beolink® variation of the MX 4000
    Why would I choose one, rather than the other?
    Mark
    Filed under: , ,
  • 09-28-2007 7:29 AM In reply to
    • Kim.t
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 18
    Re: Beovision MX4000 or MX4002
    Main diff is age and the fact that you can remote control an Avant/DVD/VCR in the main room if the MX4002 is connected with the Avant through RF- out on the Avant.
    You can still listen to music in the MX4000 if it is connected to a MCL2AV
    BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600
  • 09-28-2007 7:33 AM In reply to
    • deaddruid
    • Posts 247
    So does that mean that the 4002 is superior to the 4000, or does the 4000 have an advantage in some other area?
     Mark
  • 09-28-2007 7:38 AM In reply to
    • Kim.t
    • Not Ranked
    • Posts 18
    No
  • 09-28-2007 7:54 AM In reply to
    • deaddruid
    • Posts 247
    Um... There were two questions in that sentence. Which one is "no"? Mark
  • 09-28-2007 8:08 AM In reply to
    • Kim.t
    • Not Ranked
    • Posts 18
    MX4002 is better
  • 09-28-2007 8:24 AM In reply to
    There seems to be some confusion here!
    The 4002 is a later version of the 4000. The difference is that the 4002 has MASTERLINK
    Regards Graham
  • 09-28-2007 8:39 AM In reply to
    • Dave
    • Top 50 Contributor
    • Brisbane, Australia
    • Posts 2,328
    Oh i was gonna say, go for the 4200, it has a flat screen was similar to the BeoVision 1 Smile
  • 09-28-2007 9:10 AM In reply to
    The 4200 has the Beovision 1 chassis with a smaller screen. It has a picture quality to die for. Much more expensive than 4000/4002
    Regards Graham
  • 09-28-2007 9:12 AM In reply to
    Hi!MX 4002 was the Beolink Version of the MX 4000. It was designed as a Link-Room-TV. They have a Masterlink (ML) connection built in. The MX 4000 was designed as a Main-Room (but can`t work as a master like the Avant or AV9000)  or stand-alone TV. As an option you can fit it with an Satellite-modul! That`s not possible with the 4002!!! You can use the 4000 for a Link-Room, too. All you need is an Datalink-Masterlink converter.   So, if you are looking for a link-Tv choose the 4002. But if you need a satellite-modul it`s better to choose the 4000Sat with a converter!As a Main-Tv or stand-alone Version only a 4000 or 4200 (latest version of the 4000Series) will be the correct choise!GreetsChris
  • 09-28-2007 12:44 PM In reply to
    • deaddruid
    • Posts 247
    Thank you each for your help. Two follow-on questions, though.
    1. Is there a list of these add-on modules, such as the satellite module, somewhere on the beoworld site? I would love to see a matrix of TV models vs modules, and details on the modules.
    2. Is the satellite module designed for reception of analogue or digital signals?
    Thank you,
    Mark
  • 09-28-2007 1:08 PM In reply to
    Mark,
    I think Beomaster really answered your first question, but I will state it in a different way:-
    1. The MX4000 can have an Beosat LM fitted and that is the only option as far as I am aware.
    2. The Beosat LM is for analogue reception.
    3. The MX4000 has datalink and the MX4002 has Masterlink
    Regards Keith....
  • 09-28-2007 1:29 PM In reply to
    • deaddruid
    • Posts 247
    Thank you Keith.
    I'm afraid that I still have difficulty working out what can go into what. I guess this is a natural consequence of a supplier where we are supposed to rely on them to sort it out. This is fine for new equipment, but confusing when collecting electronic antiques.
    Mark
  • 09-28-2007 1:40 PM In reply to
    Mark,
    As Graham said the MX4002 is a later product than the MX4000
    The MX4002 has Masterlink meaning it is compatible (i.e. the same as Masterlink today) on current B&O products. Because it is a link product there was no requirement for such extras as a satellite module actually in the TV itself. If you wanted to view satellite on your MX4002 you would connect the MASTERLINK to a master video device such as an AVANT which could have a satellite module fitted in it and those satellite programmes can be called up in the on your MX4002 in the link room
    Regards Keith....
  • 09-29-2007 4:07 PM In reply to
    • deaddruid
    • Posts 247
    That's very clear now. Thank you, Keith. Mark
  • 09-30-2007 2:43 AM In reply to
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    Keith Saunders:
    Mark,
    Yes, but they were sold side by side for approx eigth years - so a 2nd hand 4002 could in theory be up to eight years older than a 2nd hand 4000.
