1st March February 2012
Latest post 09-27-2007 6:38 AM by damatt. 25 replies.
09-20-2007 5:32 AM
hagan
- Joined on 05-19-2007
- Posts 128
Hi! When is the new beovision 7-32 and 40 due to release? regards
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: New beovision7, when?
Nobody knows... probably not even B&O!
Milton78
- Joined on 06-04-2007
- Posts 130
Hi, According to my retailer here in Stockholm, probably October or November, but they didn't know anymore. We just have to wait and see.
meandmyshadow
- Joined on 04-17-2007
- Posts 339
I think 1st October is a little optimistic, I would expect November. Also there are no plans, that I am aware of, to change the chassis in the 32" version.
macsat
- Posts 40
The 32" version will change to BeoSystem 3 based, just as the 40" version. The 32" will not be 1080p though (Full HD). Release dates are still unknown. But it will happen "soon" - which could mean more or less everything when it comes form B&O ;-)
Munin
- Posts 99
The Beonic Man: 1 October 2007.
Is this just wishful thinking - or have you got this info from the inside? /M
Munin
- Posts 99
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
hagan: When is the new beovision 7-32 and 40 due to release?
My assumption is that it will be featured/detailed in the forthcoming 2007/2008 catalogue, available in October, so November? November was the date originally given to me by my local dealer and would probably make a lot of sense - people will want to order the product detailed in the catalogue....and if that says 4 HDMI sockets, they can't be sold a BV7-40 with a single DVI, can they? :)
DiaBandO
- Limburg
- Posts 124
Well, it can't take that long anymore..... My dealer has seen the new BV 7-40 (based on the BS 3 chassis) during the dealermeeting in Berlin. The "old" and the "new" BV 7 stood next to each other and he said that the picture improvement was significant on the new one. Can't wait to see it in flesh...
Just because it's mellow it doesn't mean it's less evil....
jk1002
- Boston USA
- Posts 1,620
>> he 32" version will change to BeoSystem 3 based, just as the 40" version.<<
Crossing my fingers that this will happen and that they bring it to the US. That would be the TV I go for.
linder
- Posts 653
jk1002: >> he 32" version will change to BeoSystem 3 based, just as the 40" version.<<
Great minds think alike. The 32" version would be great for me also. I hope B&O brings it to the US soon.
Beosound 5 BL9 BC2 BL8000 Beovision 7 BL6002 BL11
Kellogg
- Joined on 09-21-2007
- Posts 52
Hi, I was told by my dealer that the beovision 7-32 will NOT come in an updated version with BS3; only the beovision 7-40 will come in an updated version with BS3. However.he also told that B&O will come with a module for beovision 7 that converts the DVI conection into 4 HDMI connections. Both the audio and picture will be transfered in the HDMI cable and then the module will route the picture signal to the DVI connection and the audio to the digital audio in connection(s). With this module you can still get HDMI connections to e.g. an beovision 7-32 MKIII. Cheers, Lars.
jk1002
- Boston USA
- Posts 1,620
They would have to do something about the current chassis. That is too far behind. At the same time, I think the 32" inch can not get the BS3 simply because of pricing. I am still surprised that they do that for the BV7 40 in Europe. What is a bit frustrating for me is, that I like to buy more B&O and start bringing my current system to the next level by adding TV. Have no space though for the 40" and I do not want the TV to dominate the living room to beginn with. I just don't want to buy BC2, BS3, BL7 and projector and then find that they introduce the 32" a bit later.
So I don't think the HDMI module will solve their problems. By the way, similiar hubs are already available form other brands. So the single DVI conenction is not the problem per se.
moxxey
- South West, UK
- Posts 2,360
jk1002: They would have to do something about the current chassis. That is too far behind. At the same time, I think the 32" inch can not get the BS3 simply because of pricing.
I think you could be right. I guess we'll know as soon as the new catalogue is released - that contains the specs of their 2007/2008 models, which will have to list the new specs of the forthcoming BV7-32. Should be interesting and only 3 weeks until we get to know..
Bingo
- Posts 922
I don't expect the release of the new Beovision 7 before spring 2008. But I am sure it will be worth the wait. I expect the picture quality to be dramticly better, due to the use of another LCD panel, maybe even LED backlight used.
jk1002
- Boston USA
- Posts 1,620
" that contains the specs of their 2007/2008 models"
See they could just produce an inlet with updated specs. They have done similiar things before, for example with the MKII upgrade of the US BC2 that came end of 2006 I believe.
It still would be very nnice if they could manage the BV7 32 with a BS as a chassis. You would really get something for your money, even with a non full HD panel which wyou woudn''t need anyway.
petrosbeli
- Joined on 05-04-2007
- Posts 14
Kellogg: However.he also told that B&O will come with a module for beovision 7 that converts the DVI conection into 4 HDMI connections. Both the audio and picture will be transfered in the HDMI cable and then the module will route the picture signal to the DVI connection and the audio to the digital audio in connection(s). With this module you can still get HDMI connections to e.g. an beovision 7-32 MKIII.
This is something I've been waiting for... Does anyone have any more information? Is it going to be software controlled by the TV? (i.e. will it be switching automatically to the correct source?) When is it coming? Br, Petros
Kellogg
- Posts 52
Petros, I have no clue about how it will be controlled. As far as I understood from my dealer, we can expect this module fairly soon (what ever that means!) BR, Lars.
Beolab
- Joined on 05-18-2007
- Sweden
- Posts 535
wtlc2zpx:
So next week your are able to order !? Thats great if it´s true!!! (Week 39 is it now)
gofer
- Joined on 08-26-2007
- Posts 27
My dealer (in Switzerland) told me today that its now available to order at the same price as the current version. He seemed pretty sure....
PhilLondon
- London
- Posts 2,545
I am just guessing, but I suppose it is going to be at the same price, but without the remote... Just an intuituion. Oh and my dealer said to me that the Beo5 will be a contrained product (available through a waiting list) until the new BV7 is released. p.
