Hi
After 24 hrs of soaking in oil the brass rod moves up and down unfortunately it still doesnt lift. Having looked inside the casing seems to have shifted and their are a number of loose wires not sure whether they should be loose or not??? Moved the central pin that goes through the brass hole but it was attached to a loose piece of brown plastic??
Screwed it all back together connected to the speakers and no sound!! Even with headphones. The radio works Hadnt tested the sound before due to it scraping along the record.
Bottom line is it must have been thrown about in the post ive also found in its box a side panel off something not sure what it is possibly right hand side of the turntable.
Does anybody want this as a project? i have very basic knowledge and this is too complicated. Phoned b&0 they are not interested in repairing.
Such a shame but if anybody wants my 5th prize they can have it and I will post in the UK only it is such a nice beocenter !
Thanks for all your help
Andy
