Latest post 09-14-2007 10:43 AM by Beobird. 2 replies.
Page 1 of 1 (3 items)
  • 09-14-2007 9:10 AM
    • Beobird
    • Top 150 Contributor
    • Joined on 04-19-2007
    • Netherlands
    • Posts 506
    • Gold Member
    which din to rca converter ?
    I'm a owner of a bc9500 and I wan't to connect the pc on the aux. I'm now using a normal converter but I wan't to upgrade to a better cable and I'm just wondering what will be better: I already own some Xindak fs 03 speaker cables http://i63.photobucket.com/albums/h127/Rob_Eric_Blank/HT%20en%20stereo/DSC_1517thumb.jpg
    Only this cable
     or this one + a Xindak interlink
    it will be connected to my Onky pci 200 soundcard
    We Can't Get Enough B&O Stuff...
  • 09-14-2007 10:29 AM In reply to
    Re: which din to rca converter ?
    You want as few connections as possible - the top one will do nicely. I'm sure you can get the second one with male plugs, to go straight into your soundcard.
    I got a set of interconnects from flashbacksales.co.uk
    Very happy with those -- one set looks a bit like your top one.
  • 09-14-2007 10:43 AM In reply to
    • Beobird
    • Netherlands
    • Posts 506
    • Gold Member
    soundproof:
     it's the same site Big Smile
    If it is possible to get the second one with male plugs and 5mtr cable I will buy those ones because they've got a 24k plated din plug and a 24k rca plug Smile
