Before I buy a DVD recorder, can someone please tell me which format(s) of DVD are playable on my DVD1? My user guide doesn't say!
Do I therefore assume by this omission that, with the exception of possibly DVD RAM, it plays all the other types?
I don't want to buy a recorder which records only to discs that the DVD1 won't play!
Thanks in advance.
My DVD1 plays DVD-R ok havnt tried any other formats.
Cheers
Peter
The following formats will playback on a DVD1 PROVIDED it is not an early version where there can be some issues:-
DVD -R DVD +R DVD -RW DVD +RW
Having said the above DVD -RW has never been part of the B&O spec and in early versions they would not playback DVD -RW discs
Regards Keith....
3 different drives have been used in the DVD1! Tell us which one you are talking about.
- Type 4620- Type 4620 from serial 16255681- Type 4621-4627
