Latest post 09-12-2007 5:57 AM by Zwets. 4 replies.
Page 1 of 1 (5 items)
  • 09-10-2007 11:42 AM
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    DVD1 disc formats
    Before I buy a DVD recorder, can someone please tell me which format(s) of DVD are playable on my DVD1? My user guide doesn't say!
    Do I therefore assume by this omission that, with the exception of possibly DVD RAM, it plays all the other types?
    I don't want to buy a recorder which records only to discs that the DVD1 won't play!
    Thanks in advance.
  • 09-10-2007 11:46 AM In reply to
    • Beonut
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Essex, UK
    • Posts 89
    Re: DVD1 disc formats
    My DVD1 plays DVD-R ok havnt tried any other formats.
     Cheers
    Peter
    My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
  • 09-10-2007 2:55 PM In reply to
    The following formats will playback on a DVD1 PROVIDED it is not an early version where there can be some issues:-
    DVD -R   DVD +R   DVD -RW  DVD +RW
    Having said the above DVD -RW has never been part of the B&O spec and in early versions they would not playback DVD -RW discs
    Regards Keith....
  • 09-10-2007 3:07 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    3 different drives have been used in the DVD1! Tell us which one you are talking about.
    - Type 4620
    - Type 4620 from serial 16255681
    - Type 4621-4627
  • 09-12-2007 5:57 AM In reply to
    The types have always been a puzzle to me. I have a type 4620 which van play MP3 cd's (Philips interface), but I have allways been led to believe that only type 4621 can play MP3.
