Hello.
I bought a Beocenter 1400 (in almost perfect condition and just 25 euros!). It had some troubles with the switches at start (both channels not come up in FM section unless the button was pressed several times etc.) but I opened the case (not too easy, you know!) and used some contact cleaner and now the switches are working Ok. But there are still some more things that I wonder:
 1) The lamp of Stereo signal was not working and I took it out and it was broken to several pieces. What type of lamp is it and where I could get a new one? How can I took the whole lamp cover out (as there seems to be some pieces of glass left in)?
2) When I switch to MW or LW, the tuning-lamp comes up as it should. But with FM area it stays black. Is that normal? I have a two-wire antenna attached and as the channels come up well I guess it not too weak signal-matter.
3) When turning the built-in cassette deck on, a red light comes up. If I turn the recording on, there is no level indication (which I believe, should be done by some lamp). Possibly just the lamp should be replaced?
In the case of the lamps, I would be pleased to hear from where they could be bought. I can pay with PayPal, so that's not a problem.
Thanks for any help in advance!
									    Bang & Olufsen - The art of controlling sound, picture and light
