Latest post 09-16-2007 2:59 PM by Frank Rizzo. 16 replies.
Page 1 of 1 (17 items)
  • 08-23-2007 11:39 PM
    Beolink 7000
    Just got my Beolink 7000 from Ebay....and got it charged....Can I run a test on it without any equipment (only the charger)???
    What buttons do i push to tell what software it has???  The manual is really not that clear (button 2)?????
    THanks...K
  • 08-24-2007 3:56 AM In reply to
    • Tibor
    • Not Ranked
    • Joined on 04-16-2007
    • Budapest, Hungary
    • Posts 36
    Re: Beolink 7000
    To bring the BeoLink 7000 into the test mode you have to apply 10Hz TTL (0-5 Volt) signal to the data input pin at the back of the equipment for at least 2 seconds when the unit is switched on.
    So, you have to have a TTL signal generator to do it...
    I also would like to check mine, but at the moment I have no signal generator [:-(]
    Tibor
    Next step: BV7-40 or BS3 with projector ?
  • 08-24-2007 10:28 AM In reply to
    Beolink 7000 upgrade?
    Is it possible to upgrade an old Beolink 7000 to the RDS-model?
     /Ola
    Filed under:
  • 08-24-2007 11:20 AM In reply to
    Re: Beolink 7000
    Thanks Tibor....
    Also,...Does a Beolink 7000...when it's in the motorized "up" position...have some "play" at the top.????   ie...it's kinda loose..???
    Thanks...
  • 08-24-2007 11:30 AM In reply to
    Re: Beolink 7000
    There is a little bit of movement but not too much.
    When you look at the remote from behind, you will see a small motor that holds it up which is quite small in comparison to the size of the remote itself.
    You may get no contact coming up as nothing will be communicating with the 7000 aswell so dont panic!
  • 08-24-2007 3:13 PM In reply to
    Re: Beolink 7000 upgrade?
    I am guessing that you have a non EU version if you are asking this question.
    What is the Type number of your Beolink 7000 ?
    Regards Keith....
  • 08-24-2007 3:27 PM In reply to
    Hey Keith.....quick question.....
    Where on my Beolink 7000 does it say the Type???  I can't find that and i'd like to know what software it's running..
    THanks ,  another Keith...
  • 08-24-2007 4:45 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-17-2007
    • New Zealand
    • Posts 119
    The type number should be visible from underneath when the remote is folded up in table position.
    To change the software requires changing one of the PCBs, and also the glass front panel as they have slightly different key layouts. It would be more cost effective to purchase another 7000 remote with RDS if you want that function.
    In my opinion the RDS has limited value as it is only displayed on the blue LCD briefly when the remote is active.
  • 08-24-2007 7:59 PM In reply to
    Hi...thanks...it says....Beolink 7000 RDS    Type 1633    SW 3.1
     What does that all mean?????
  • 08-24-2007 8:04 PM In reply to
    Re: Beolink 7000
    Hi Mobey...it seems that if you motor it up....and set it on the table....then look at the "highest" point of the remote....it will move up approx. 1 cm or a tad less....and then you release it and it moves back down that 1 cm or less ....
    Is that normal??
    Gracias...
  • 08-25-2007 4:30 AM In reply to
    The BL 7000 I'm planning to buy is a type 1540. I think that this is a EU-version?
    /Ola
  • 08-26-2007 5:05 AM In reply to
    • Tibor
    • Not Ranked
    • Budapest, Hungary
    • Posts 36
    Type 1633 was the MKII USA version with latest 3.1 software produced until 1996 - as far as I know.
  • 08-26-2007 12:58 PM In reply to
    Thanks Tibor !!!!!!!!
  • 08-26-2007 2:34 PM In reply to
    I can confirm the feedback provided by Tibor.
    Regards Keith....
  • 08-26-2007 3:38 PM In reply to
    Gracias...Keith.....!!
  • 09-15-2007 12:23 PM In reply to
    I'm lookin for a new front plate (blank alu) for my BL7000.
    I have tried with my local dealer but they say it's sold out.
    Does anyone know or have one extra?
    /Ola
  • 09-16-2007 2:59 PM In reply to
    Same here...need LCD light, mirror, glass plate and nose piece that you shoot the IR through..
    Anyone??
