Hi Peter,
when you have found the station you want to save you need to then enter a preset number to store it on then press store twice. I think that's right - been a while since I've done this. I'll double check for you if this doesn't work.
There are only three ways to cancel the loudness function and the beo4 cannot do it.
1. Use a MCP 5500 to do it.
2. Find a MK1 or 2 beolink 1000 with the reset button. (are there any members in Sweden who could lend you one?)
3. Disconnect the internal battery for a few minutes - obviously this is the least desirable option.
Chris.
