Hi Martin,
I have similar problem - I purchased a Beosystem 7000 on the e-bay.
On last Monday, when I picked up personally the system from the seller the Beocord 7000 was working fine.
At home it was able to play in any direction and rewind only for one-two seconds and then stops automatically. Fast forward works eventually.
Could it be a belt problem or something else ? Maybe something could happened during the travel? I carried it as hand luggage and of course with the four plastic fixation screws. Thanks in advance !
Tibor
Next step: BV7-40 or BS3 with projector ?
