(moderator, maybe this should be moved to the workbench ??)
Assuming you know a bit about servicing tv's / electronics:
start with measuring the HT transistor if it's short circuit and while you're there check the C connected to the collector of this transistor, i believe it's called C102 (6n8): a common fault is that the solderings of these get lose.
check if the stand-by power (8 volt) is ok.
chech with ohm meter (tv unplugged!) the loads on the output of the power supply (so the +15, +8, +135 etc) to see if there's any unusual low load.
check for bad solderings in the power supply area (especially the part of the PCB from the BUT11 in the power supply in dthe direction of the HT transformer, about 2-3 inches away from the BUT11), you may need a magnifying glass...
