Latest post 04-04-2011 7:44 PM by Jandyt. 137 replies.
Page 2 of 6 (138 items) < Previous 1 2 3 4 5 Next > ... Last »
  • 08-12-2007 3:44 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: D I Y foam replacement on S120s. Step by step with photo's....... by Andy T
    Next I started working on the speaker frame.
    I did this with a blunt Stanley knife. The whole Knife was too bulky so I removed the blade and held it in some folded up kitchen roll.
    It took about 45 minutes to go round the frame, milimeter by milimeter! I always kept a thumb or an index finger between the blade and the cone so as not to have any little accidents.
    After I had done I did the same as before and used cotton-wool soaked in meth's to clean any remnants off.
    Do you know, I think my fingers are better than those in the infamous Beo5 photo'!
    Poor me, never win owt!
  • 08-12-2007 3:47 PM In reply to
    • Jandyt
    • Posts 13,004
    I then, ever so gently pulled any large pieces of foamrot away from the cone itself.
  • 08-12-2007 4:34 PM In reply to
    jandyt:
    Did also put them in the sink with some Fairy liquid ???Laughing
  • 08-13-2007 3:56 AM In reply to
    I am still impressed by the bottle of Captain Morgan and the pint glass.......Surprise
    Simon.
  • 08-13-2007 4:17 AM In reply to
    • Jandyt
    • Posts 13,004
    Thanks Simon!
    I didn't think anybody had noticed. Did you spot the sledge hammer too?
    Andy T.
  • 08-13-2007 4:22 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    For anyone with concave "domes" (which Andy used a vaccume cleaner to pull out) - I wouldn't worry too much about this if you're a bit dubious about tackling them. They are really there to stop any dust getting into the drive coils and wearing them out. They don't actually affect the performance of the speaker by being dented.
    Replacement dust caps are avaiable though if Andy's trick doesn't work and it bothers you (it would meStick out tongue)
    Andy, when you fix the new surrounds start by attaching the inner edges to the cone first and leave to dry completely before starting on the frame edges. It is also vital to ensure the coils aren't rubbing before the glue on the outer edges (frame) are allowed to set. This is easy to check by gently pressing the dust cap in the centre in a straight perpendicular line. Any slight rubbing at all and you will have problems, they should move absolutely freely.
    Please tell me to shut up if I'm teaching you to suck eggsSurprise
    Chris.
  • 08-13-2007 2:30 PM In reply to
    • Jandyt
    • Posts 13,004
    Much appreciated Chris.
    I am following the instructions provided by Audiofriends and your instructions are almost word perfect to his!
    Thanks a lot for that. There is something I need to know that you may be able to help me with.
    Craig kindly gave me two female plugs to go in the back of the S120s and I will get some cable and pugs for the other end from Maplins.
    On a driver, it doesn't matter which wire goes where but on a passive speaker with an elaborate crossover circuit board does it still not matter?
    Andy T.
  • 08-13-2007 2:35 PM In reply to
    • Jandyt
    • Posts 13,004
    And now the bit I'm not looking forward to.
    To remove the foamrot from the cone is quite time consuming.
    First, with a cotton bud, I wetted the foamrot with meths. (Keep well away from sink and Fairy liquid Wink )
    Sorry, poor photo'.
  • 08-13-2007 2:39 PM In reply to
    • Jandyt
    • Posts 13,004
    Then, holding the Stanley knife blade at a steep angle, start scraping the black stuff away. It's more of a scraping motion than a cutting one, a bit similar to shaving with a cut-throat razor. Three scrapes then wipe the blade.
  • 08-13-2007 2:41 PM In reply to
    • Jandyt
    • Posts 13,004
    This will still leave behind some of the old glue (yellowy brown in this photo').
  • 08-13-2007 2:45 PM In reply to
    • Jandyt
    • Posts 13,004
    Then, from underneath, cut the glue.
    Fred's instructions shows him using scissors but I don't trust myself.
    From underneath you can see the line which is the actual edge of the cone and so can cut in a sawing motion following this line.
  • 08-13-2007 2:49 PM In reply to
    • Jandyt
    • Posts 13,004
    A quick clean off with meth's on a piece of kitchen roll and the first driver is foamrot free.
    Over the sink brush any bits off with a soft dry paintbrush.
  • 08-13-2007 2:50 PM In reply to
    • Jandyt
    • Posts 13,004
    Before and after.
  • 08-13-2007 2:53 PM In reply to
    • Jandyt
    • Posts 13,004
    An hour and a half later.....
    VOILLA!!!
    Now the delicate job of gluing begins.....but not today.
  • 08-13-2007 4:32 PM In reply to
    Awesome pics, you have far more skill and patience than I have!
    Simon
  • 08-14-2007 3:30 AM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    The polarity relationship of the drivers is important to prevent phasing issues. The drivers/crossover should be wired so that the driver cones move in the same direction with the same polarity signal (and the other speaker should obviously be identically wired). This will ensure you have no problems playing the speakers as a pair.
    (Hope you're not doing this on Wednesday)!
  • 08-14-2007 4:08 AM In reply to
    • Jandyt
    • Posts 13,004
    Thanks Puncher. So, in laymans terms, flat pin in amplifier to flat pin in speaker, yes?
    Don't worry about Wednesday, inane drivel will be spouted!
    Andy T.
  • 08-15-2007 3:08 PM In reply to
    • Jandyt
    • Posts 13,004
    The next thing is to glue the new foam to the cones NOT the frames.
    First of all, as I don't want surplus glue all over the place and end up with a Mobe job, I drew a line all arround the cone just a little bit shy of the foam surrounds, This allows for a little bit of squashage.
    To get the line equal all the way round, I taped a pen to an upsidedown pencil and used this as a guage.
  • 08-15-2007 3:13 PM In reply to
    • Jandyt
    • Posts 13,004
    And then very carefully, using a childs paint brush, applied the "special" glue to the cone
  • 08-15-2007 3:16 PM In reply to
    • Jandyt
    • Posts 13,004
    Here I am applying the glue to the new foam surround,
    Notice I have kept slightly away from the edge to allow for squashage. (I made this word up but it sounds great so I'll keep using it)
  • 08-15-2007 3:29 PM In reply to
    • Medogsfat
    • Posts 4,045
    Judy:
    Laughing
    If your reading this Mobe - you realise you have now found eternal infamy on here don't you?
  • 08-15-2007 4:06 PM In reply to
    • Jandyt
    • Posts 13,004
    Now, the instructions said to let the glue set until it's two thirds white and one third clear.
    This looks about right
  • 08-15-2007 4:58 PM In reply to
    looking good Smile
  • 08-15-2007 6:07 PM In reply to
    • Jandyt
    • Posts 13,004
    Then slowly and very carefully lower the foam surround onto the cone.
    I used my fingers as a guage to get it as central as possible.
  • 08-15-2007 6:14 PM In reply to
    • Jandyt
    • Posts 13,004
    Very carefully, with middle fingers behind and thumbs in front squeeze together the surround and the cone.
    Just like tightening up a cylinder head bolts start at 12 o'clock then 5,10,3,8,1,6 etc. Round and round about four times
