Latest post 04-04-2011 7:44 PM by Jandyt. 137 replies.
Page 5 of 6 (138 items) « First ... < Previous 2 3 4 5 6 Next >
  • 08-20-2007 3:15 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: D I Y foam replacement on S120s. Step by step with photo's....... by Andy T
    On one of them, the angled bit that goes over the top has been splayed open
    Poor me, never win owt!
  • 08-20-2007 3:16 PM In reply to
    • Jandyt
    • Posts 13,004
    And the one on the left is slightly bent wher someone has rived it off
  • 08-20-2007 3:20 PM In reply to
    • Jandyt
    • Posts 13,004
    What I am about to do is a calculated risk!
    Please don't try this at home!!!
  • 08-20-2007 3:32 PM In reply to
    • Jandyt
    • Posts 13,004
    Now I'm not sure, but I would imagine that the glue bonding the fabric to the frame is probably water-based.
    I filled the sink up four inches deep with warm water and added a dash of Angastora bitters Fairy liquid.
    With nail brush at the ready, I quickly dunked the first one and scrubbed manically, all over, back and front then whipped it out of the water.
    Shook it vigorously and then got the hair-dryier on it before the glue dissolved. It was only in water for about twelve seconds.
    Did the same with the other three.
  • 08-20-2007 4:09 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    I washed my speaker frets as well from a pair of S55's. Can't remember how long they were in the water but I didn't rush!! They came out so nice and clean afterwards!
    Durban South Africa
  • 08-20-2007 4:20 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Yes, handwarm water, no more or you will risk shrinking the cloths, combined with the cheapest hairshampoo you can find.
    Shower the frets with water,
    Rub the shampoo in gently using your hands and let it work for a couple of minutes,
    Scrub gently using a nailbrush if you have some stubborn dirt (gently !),
    Shower the frets using handwarm water 'till all of the shampoo has come off.
    Leave to airdry, please no hairdryer. The hairdryer will be fine for some types of cloth but not for all and you won't know before it's too late.
    Especially some of the Beovox Uniphase series (S22-S45) where at least two different types of cloth has been used seems to be prone to shrinkage caused by excess heat, sometimes towards the extreme (impossible to mount back onto the cabinet!).
    I never saw any speaker cloth glue dissolve in water but of course it shouldn't be left to soak for hours.
  • 08-20-2007 5:54 PM In reply to
    • Jandyt
    • Posts 13,004
    Once clean and dry, it was quite easy to sort out the splayed out one.
    A dot of superglue on each of the four places where it was snapped.
    As for the bent bit, a doddle! I just held it at the edge of the curved kitchen work-top and a few short taps with the wooden handle of a pin hammer and it was soon flat and level.
    Now for the locating pin-thingys
    I managed to find some wall-plugs that were a fairly tight fit in the holes on the enclosures.
    I cut one down to the same height as the surviving pegs and found a thin screw which would reach through the wall plug, and a little more.
    I then held a pointy bradall in the flame on the gas hob and immediately melted a small pin-*** hole through the center of the cut off locating pin.
    Just before screwing it tight I put a small drop of super glue in the hole and on the cut-off wall-plug then screwed it home.
  • 08-20-2007 5:55 PM In reply to
    • Jandyt
    • Posts 13,004
    It worked wonderfully so I repeated the procedure with the other two.
  • 08-20-2007 5:58 PM In reply to
    • Jandyt
    • Posts 13,004
    All that remained was to introduce the frets to the speakers.
    Unbelievably, they just slotted into place as if they were new frets!|
    That's it, job done!
  • 08-20-2007 6:07 PM In reply to
    • Jandyt
    • Posts 13,004
    I made up a couple of speaker cables with two sockets donated by CraigYes -  thumbs up and two plugs I bought from Maplins.
    This was about 3.30 this afternoon (Mon) and I was just about to plug them into my Beomaster 7000 when my son and his fiance arrived for a brew.
    Well, I sat them on the settee and connected up the speakers.
    Most of you will already have guessed which DVD I put on the Kikinoko DVD player!
    I muted the Avant speakers and set the 7000  to volume 36 with my newly refurbished S120s.
    I scrolled through to Hotel California and pressed play.............
  • 08-20-2007 6:31 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    ......then the doorbell rang, and it was the local Vicar come round for a cup of tea and a chat - so you muted it..
    And after discussing the local community centre, the knitting circle, and the problem with teenagers hanging around outside the local 7-11 all night he left and you then got back to pressing play.. and...
    Hmm
  • 08-21-2007 3:54 AM In reply to
    • Jandyt
    • Posts 13,004
    .......and, Ohh! The sweetness of the air!
    A warm glow swept over me as the introductory trumpet solo played. I gradually incresed the volume to 50 and the kids turned and looked at each other.
    What a nice pure sound. Sharp and clear with no vibrations or dead spots.
    I had done this!
    As the trumpet faded away and the guitars started, I got the goose-pimples just like I had that day in Frede's house in Venø, near Struer.
    It's hard to believe these are passive speakers.
    I feel really proud of my handywork and glad I took them on.
    Near the end of the track, where there is a guitar duet, I threw all caution to the wind and cranked up the volume to max, 78.
    The whole room was vibrating, my sons eyes nearly popped out! The speakers handled it well and supprisingly didn't cut out.
         Success. Thank you for following this thread.
    I have two dillemas now. What will I do with these lovely speakers? and what will my next photo-journal be about?
    Andy T.
  • 08-21-2007 4:01 AM In reply to
    What a magic thread Andy. Well done!Yes -  thumbs up
    Regards Graham
  • 08-21-2007 4:10 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Excellent thread and an excellent job - very well done Andy.Yes -  thumbs up
    I know exactly how you feel though. The 1st speakers I ever refoamed were S55's and I too was totally gobsmacked that my efforts were equally successful. It has inspired me to carry on refurbishing other speakers in the B&O range with the knowledge that anything is possible with a little patience and planning.
    Chris.
  • 08-21-2007 4:42 AM In reply to
    Congratulations on a job well done!
     If you really can't find a home for them I might be able to help........Laughing
     Simon
  • 08-21-2007 9:53 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Hi Andy,
    A great thread - well done! I love to see other simple people like me, taking the initiative and making the effort to do the job well (and succeeding, to boot), instead of farming out work to local technicians who can't be bothered to care about professionalism any more!
    I'm starting on my 4 S45's in a few days to replace the Crossover capacitors. I just got the new Auricaps in the mail yesterday. I'll post that project also.
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 08-22-2007 8:06 AM In reply to
    • h1npw
    • A cricket ball throw from Trent Bridge
    • Posts 776
    What an absolutely fantastic superb thread Andy. Your use of plain English and good photos is an example to us all. As a fan of older B&O, threads like these are what makes this site special (and easily worth the £30 for gold membership - never mind the monthly draw !) for me. The thrill of rescuing and refurbishing an item like these speakers to the standard that you've achieved is something that should be experienced by everyone !
    A few questions.....not necessarily for just you to answer, Andy
    What was that Olympus device in the pics ?
    There must be a similar product available to day to the scratch remover you've got - the results look amazing. Can anyone suggest anything ?
    Can Dillen give us more information & photos about shims, spiders, where to purchase the best quality foam surrounds etc, so us lesser mortals can be educated in the ways of repairing the trickier models.
    Cheers
    Nigel
  • 08-22-2007 8:14 AM In reply to
    yachadm
     I await your post with interest as I am about to tackle the same job on my S45-2 s as soon as the capacitors arrive in the post.
    Simon
  • 08-22-2007 2:16 PM In reply to
    Well done!
     Great read. My pair of Beovox M150 has no foamrot but the cabinets have a few scratches and some of the fret plugs broken.
    I learned a few important things here so thank you.
  • 08-22-2007 2:20 PM In reply to
    • Jandyt
    • Posts 13,004
    Thank you for your kind words Nigel.
    I came over with a warm glow when I read that, makes all my work worth it.
    The little black Olympus device is a remote control for the camera. I couldn't have done most of the photo's without it.
    (I didn't really use my ear lobe!)
    Andy T.
  • 08-22-2007 2:23 PM In reply to
    • Jandyt
    • Posts 13,004
    And thanks to all of you who have made kind commentsYes -  thumbs upBig Smile
    Andy T.
  • 08-22-2007 5:33 PM In reply to
    Nigel
    A thin covering  of teak oil covered a mulitude of sins on my S45-2's. I wouldn't say the scratches disappeared, but you only notice them when you look closely.
    Simon
  • 08-23-2007 7:44 AM In reply to
    • h1npw
    • Posts 776
    Thanks Simon
    Cheers
    Nigel
  • 08-23-2007 1:41 PM In reply to
    • classic
    • Top 500 Contributor
    • Venø - Struer / Denmark
    • Posts 224
    jandyt:
    Hi Andy,
    Great job - really - - - I am looking for some help in my small business - now I know who to contact Yes -  thumbs up
    The one and only pease of music for really enjoying the sound of the B&O products, I do hope to find more of that recorded quality.
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
  • 08-23-2007 4:11 PM In reply to
    • Jandyt
    • Posts 13,004
    Cheers Frede.
    You know, people remember where they were at gret milestones in their life.
    I know where I was when Neil Armstrong stepped on the moon and where I was when Elvis died or Princess Diana.
    I also will always remember where I first heard that version of Hotel California, In a small thatched cottage on the island of Venø!
    Glad you enjoyed the thread mate.
    Andy T.
