Latest post 08-11-2007 5:06 PM by Jandyt. 8 replies.
Page 1 of 1 (9 items)
  • 08-11-2007 4:24 AM
    Product Configuration Guide
    Please note that the guide has been updated and the latest version is available
    http://www.beoworld.org/manuals_view.asp?pid=1238
    Remember to change the file extention from .pdf to .exe before running the file.
    The PCG will then be available in your START>PROGRAMS>BANG & OLUFSEN folder.
    Regards Graham
  • 08-11-2007 8:42 AM In reply to
    Re: Product Configuration Guide
    Graham,
    Do people actually use this tool, its rather limited and also assumes you will have a maxmium of four link rooms ?
    Regards Keith....
  • 08-11-2007 8:54 AM In reply to
    I've never had to use it Keith but some people seem to think it is very useful.
    Regards Graham
  • 08-11-2007 9:54 AM In reply to
    I think it is actually quite useful as it gives you detailed set up instructions for each room as well as option setting instructions. Most rooms will actually be similar after 4 so you don't need to do each room. I don't use it as it only works on a PC but I think it is rather fun!
  • 08-11-2007 11:13 AM In reply to
    Yes, it is very useful, especially when you've got a mix between old and new products (ML/MCL/DL...) as it highlights compatibility problems and minimal software versions.
     I wish there were one with the latest products as well.
  • 08-11-2007 11:56 AM In reply to
    There is!! Just updated!
  • 08-11-2007 2:45 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    I have used the PCG many times and find it very useful and, as Peter says, fun.
    Just went to download this update but can't remember at which point you change it to exe. Help please in laymans terms.
    Andy T.
    Poor me, never win owt!
  • 08-11-2007 4:58 PM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Ey -up mate!
    Right click on downloaded file - select rename from the list - replace the .pdf with .exe. Click outside the box to save changes and Bob's yer aunt's husband. Double click the .exe file to install the PCG.
  • 08-11-2007 5:06 PM In reply to
    • Jandyt
    • Posts 13,004
    Cheers Miduck
