Please note that the guide has been updated and the latest version is available
http://www.beoworld.org/manuals_view.asp?pid=1238
Remember to change the file extention from .pdf to .exe before running the file.
The PCG will then be available in your START>PROGRAMS>BANG & OLUFSEN folder.
Regards Graham
Graham,
Do people actually use this tool, its rather limited and also assumes you will have a maxmium of four link rooms ?
Regards Keith....
Yes, it is very useful, especially when you've got a mix between old and new products (ML/MCL/DL...) as it highlights compatibility problems and minimal software versions.
I wish there were one with the latest products as well.
Mac, iPad & iPhone Apps: Beoworld, LinkPlayer, LinkRemote, Story Mouse, The Emperor's New Clothes
I have used the PCG many times and find it very useful and, as Peter says, fun.Just went to download this update but can't remember at which point you change it to exe. Help please in laymans terms.
Andy T.
Poor me, never win owt!
Ey -up mate!
Right click on downloaded file - select rename from the list - replace the .pdf with .exe. Click outside the box to save changes and Bob's yer aunt's husband. Double click the .exe file to install the PCG.
