Hi
I have a central system, including an avant, beosound 9000 and beolab 3500 and a non-B&O DVD player controlled by DVD controller. Apart from the beolab 3500 they are all in the same room. Now I recently acquired an old but properly working MX7000. This one is placed in the same room as the beolab 3500. At this moment I have installed it as a 'separate' tv with no interaction with the rest of the B&O system (for that I also set the beolab 3500 in option 5, so it does not turn on when you press tv). Would be great if I could get the picture from the DVD player onto the MX7000. The MX 7000 is of the type 7800 (produced between 96 and 99) and does not have ML connections. However, I noticed in the manual of the beolab 3500 that this piece of equipment does have both ML and MCL connections. Is it possible to connect the MX7000 to the MCL socket of the beolab 3500 and so get a connection with the ML system and therewith 'draw' the signal of the DVD player. If not possible, what DO I need? A converter like the 1611 directly connected onto the ML system?
Hope somebody can shed a light on this one,
kees
