Latest post 06-27-2008 6:08 AM by ProGram. 20 replies.
Page 1 of 1 (21 items)
  • 08-08-2007 6:16 PM
    • a11mcr
    • Top 500 Contributor
    • Joined on 07-29-2007
    • Redcar,North East
    • Posts 154
    • Silver Member
    beosound century door problem
    hi all can anyone help?
    my beosound century has a small fault.
    when i approach the unit somtimes the door will open but most times i have to slide it open myself
    does anyone know how to fix this?
    thanks all
    mark
    Kind Regards, Mark
  • 08-09-2007 1:39 AM In reply to
    Re: beosound century door problem
    Mine does the same - needs dismounting and cleaning - never find time!
  • 08-09-2007 4:56 AM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks.
    have tried this but i still have problems, could the sensor be faulty?
    is so can they be changed?
    thanks
    mark
    Kind Regards, Mark
  • 08-09-2007 5:08 AM In reply to
    If it is the same as mine, it is not the sensor but the fact the door opening mechanism doesn't engagage with the door. Does it click when you put you hand in front of it?
  • 08-09-2007 5:15 AM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    hi peter when it does move it is very smooth with no noise do you think when it is fully closed it is catching somewhere?
    mark
    Kind Regards, Mark
  • 08-09-2007 5:24 AM In reply to
    I think it is coming loose from the mounting. When you slide it manually when it hasn't opened, does it click at the end of the movement, and then will it work?
  • 08-09-2007 5:29 AM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    no there is no noise at all.
    how can i see if it is coming loose and how can it be fixed?
    thanks
    mark
    Kind Regards, Mark
  • 08-09-2007 5:50 AM In reply to
    Yours sounds like a different problem to mine. I'll let you know if I fix mine though!
  • 08-09-2007 2:51 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Ok now i have another problem?
    i remove the speaker frets and cleaned as advised (yes they were a bit dusty)
    now it has started playing up!
    when i play a cd sometimes it will stop and the door will open the the cd clamper will lift up, then close again and repeats itself two or three times then the door will close 3/4 shut and thats it.
    I then have to open the door myself and re-start the cd????
    any ideas or should i let my local dealer have a look (B&O Yarm).
    If so any idea on cost?
    thanks
    all
     Mark
    Kind Regards, Mark
  • 08-09-2007 4:11 PM In reply to
    on the big gear wheel driving the door there is an optical censor, thats tells the uP what position the door and clamper are in, when there get to mush dust in it, it can no longer point out where it is. so a good claening of the gear wheel well help.
  • 08-09-2007 4:25 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    thanks i will try cleaning the gear and sensor se how it goes but i still cant get the door to open when i go near it.
    thanks
    mark
    Kind Regards, Mark
  • 08-09-2007 4:38 PM In reply to
    It is also possible to get a new modified gear wheel, where dust shouldn't be a problem
  • 08-09-2007 5:25 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    sorted the gear problem out! it was full of dust but the door still will not open so it looks like a trip to the dealer.
    Is there anyway of testing the receiver L.E.D ?? as behind the right speaker next to the door there is a small black IR receiver and on the ciruct board there are two IR transmitters are these for the door??
    thanks so far
    mark
    Kind Regards, Mark
  • 08-09-2007 6:04 PM In reply to
    if I remember correctly there are also a transmitter or receiver placed, on the upper right hand side of the CD casing!! is there a Bright light directly on the BSC or a plasma screen in the same room?
  • 08-09-2007 6:52 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    It is in my dining room there is no tv and only a low light and a table lamp.
    how would i be able to tell? i cant see anything next to the cd?
    thanks
    mark
    Kind Regards, Mark
  • 08-09-2007 7:00 PM In reply to
    I think you should bring it to a shop, a last thing I can come up with is, did you clean the sensor on the Little pcb ontop of the gear wheel?
  • 08-10-2007 10:44 AM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Got it booked in on Wednesday
    will let you all know what the fault was.
    mark
    Kind Regards, Mark
  • 08-11-2007 6:05 PM In reply to
    Yeah, please let us all know what they say.  I'm having the same trouble with mine, and I've cleaned everything like you!
    Guy
  • 09-18-2007 1:02 PM In reply to
    • a11mcr
    • Redcar,North East
    • Posts 154
    • Silver Member
    Problem sorted!!!!
    i took it to my local repair guy Martin Farrence (in Redcar) and he carried out some mod`s and its all working fine.
    Somthing to do with the sensors (which he changed)
    and it only cost £65
    Kind Regards, Mark
  • 06-27-2008 6:08 AM In reply to
    • ProGram
    • Joined on 06-01-2007
    • NRW, Germany
    • Posts 145
    Hi!
    Does someone know, what's the improvement with the sensors? I have a century, which sensor sometimes is very weak and sometimes working well. I recognize that one of the two led's is illuminated dark red and the other is not. Are these led's the same as in remote-controls?
