Ok now i have another problem?
i remove the speaker frets and cleaned as advised (yes they were a bit dusty)
now it has started playing up!
when i play a cd sometimes it will stop and the door will open the the cd clamper will lift up, then close again and repeats itself two or three times then the door will close 3/4 shut and thats it.
I then have to open the door myself and re-start the cd????
any ideas or should i let my local dealer have a look (B&O Yarm).
If so any idea on cost?
thanks
all
Mark
