Latest post 08-03-2007 8:22 AM by Goldfrog88. 3 replies.
Page 1 of 1 (4 items)
  • 08-02-2007 10:36 AM
    • caci
    • Not Ranked
    • Joined on 08-02-2007
    • Posts 13
    Cable Adapters
    Newbie here.  I just bought a BEO 9300 from a pawn shop and would like to connect some active speakers.
    1)  I have read the FAQ's and a few postings on this forum, but want to know if anyone has schematic/wiring diagrams for the "preamp" jacks so I can build my own.
    2)  Not clear on the 7-pin DIN's - evidently, 5-pin is OK (just 2 conductors are being used per output)?
    3)  If I do buy ready-made adapters, any source/part numbers?
    4) What about passive speakers - are those jacks proprietary to B&O?
    5)  Also, on the B&O website the "manual" for the 9300 was very basic.  Does anyone have info on the operation of this unit.
    Thanks in advance,
    Chris
    Filed under:
  • 08-02-2007 11:51 AM In reply to
    Re: Cable Adapters
    Have a look at the sister site - www.Beotech.co.uk which has the wiring diagrams. If using Beolab active speakers, I would get the B&O Powerlink cables - they are actually 8 pin.
    The passive speaker connections are 2 pin DIN, available from Maplin.
    Not sure which manual is on the official site - the one on here is 44 pages. You need to be a silver or gold member to access them though.
  • 08-02-2007 11:11 PM In reply to
    • caci
    • Not Ranked
    • Posts 13
    Re: Cable Adapters
    I'm a Gold Member now - where do I find the ENGLISH 44 page manual?
  • 08-03-2007 8:22 AM In reply to
    • Goldfrog88
    • Top 500 Contributor
    • Joined on 06-07-2007
    • Melbourne, Australia
    • Posts 83
    • Gold Member
    Re: Cable Adapters
    Chris, try http://www.beoworld.org/prod_details.asp?pid=411 ; otherwise select products and then select 'User & Service Manuals' at the top right of screen. Choose 'Music Systems' then 'BeoCenter Music Centers' and 'BeoCenter 9300' and 'View Manuals'. There should be at least the user manuals there.
    Cabling pinouts for PowerLink are:
    Pin 1: PowerLink on >= 2.5V; off <= 0,5V
    Pin 2: Signal Ground
    Pin 3: Audio Left out: 0V--6.5V RMS
    Pin 4: PowerLink Speaker on >= 2.5V; off <= 0,5V
    Pin 5:  Audio Right out: 0V--6.5V RMS
    Pin 6: Data High >3.5V; Low <0.8V
    Pin 7: Data Ground
    Pin 8: No connection
    No connection to metal jacket
    Good luck!
