STIG
Thanks a lot
Trying to tie up the info in your mail to the requisite connections on my Echostar I have found out the following about my box...
Echostar Satellite Receiver Spec
Frequency range 950MHz to 2150MHz
Input impedance 75 Ohm
Signal level -25 to -65dBm
IF frequency 480MHz
IF bandwidth 36MHz
Variety of LNB polarity control; 13/18V, 0/22kHz tone, 0/12V,
LNB power & polarization
Vertical +13.5V - +14.5V
Horizontal +17.5V - +18.5V
22kHz tone Frequency 22kHz 2kHz
Amplitude 0.6Vp-p 0.2Vp-p
0/12 Volt Polarity switch
Azimuth & Skew control
6 Push terminal
(M1, M2, M.Pulse, +5V, GND, Skew)
Output power 36VDC, 5A max. (during 5 minutes) (SMPS)
Sensor type Reed or Hall effect switch
Ferrite control 2 Push terminal(+,-)
It appears that with the choice of LNB switching etc many of the connections I can fathom but I am not sure whether the Triax/B&O feedback tacho is compatible with the Reed or Hall effect switching - this remains a puzzle.
What do you think to my proposed connection sequence..
OUTDOOR CONTROL
Pin 3 B&O to GND Echostar
Pin 5 B&O to SKEW Echostar
ACTUATOR CONTROL
Pin1 B&O to GND Echostar
Pin 2 to M1 Echostar
Pin 3 B&O to M2 Echostar
Pin 4 B&O to MPulse Echostar
Pin 5 B&O to +5V Echostar
Assuming every thing is ok appart from the poloriser I suppose I could dump that in preference for a low threashold Quad band that won't need tuning up
Do you think I am on the right track? Colours of wires would alos help!!
Your continued support is a blessing
Cheers
Gary
