Hi guys...i've been working on something here that i'm trying to do...here's the situation..
On Floor 1..i've got a BS9000 linked to an active room with Masterlink....
On Floor 2 i've got a Beocenter 9500 linked to a passive with Powerlink (correct yes?)
I know i can do the following... run a Power link from Floor 1 to FLoor 2 and vise versa.... THus allowing me to click AUX. input from either system and get the sound to the other system..
BUT...what i want to do is THIS.....now it's a bit tough to bend your mind around at first...
1) Take the Beocenter 9500 on Floor 2......run a Powerlink to a MCL 2 AV...
2) Run an IR eye to theMCL 2AV
3) Connect the optional imput Powerlink (or is it AUX.) of the MCL 2AV to a ML / MCL converter....
4) Connect the Masterlink of the ML / MCL converter to the Floor 1 Masterlink system....
QUESTION....
When standing at the MCL 2 AV IR eye....and I can obviously control the Beocenter 9500...yes??
BUT...when you switch the MCL 2AV to the optional input....(where it's linked through the ML / MCL converter)....
Could I (through the IR eye of the MCL 2 AV) control the Masterlink (beosound 9000) system on Floor 1???????????
THANKS...
Keith
