1st March February 2012
Latest post 12-23-2007 1:10 PM by Dillen. 10 replies.
07-25-2007 8:52 AM
Jeff
- Joined on 07-25-2007
- London
- Posts 10
Hi Guys, I have recently purchased a BeoCenter2400-2, with BeoGram 2400, a pair of S50 speakers, all housed in a lovely MC40 Cabinet. As it was an ebay purchase, and therefore sold as seen, there are a few minor niggles that I would like to ask some advice on. I have had a few different B&o systems in the past, all with their quirks, but would like to restore this one to it's former glory. 1. The right hand side of the volume display is not visible, as well as the displays for bass/treble etc - are these just blown bulbs, and if so, what are the recommended replacements? 2. One of the bass speaker cones is worn through, and although it plays OK, would be good to get a replacement- any ideas where you can get replacements? 3. I would like to ideally plug a seperate CD player, and also a lead for an ipod or digital radio into the 'Tape' input. Would ideally like a B&o CD player, but may have to wait for a while to find the right one- any suggestions? Also, is it possible to use some kind of plug that could go into the DIN socket, and give two (or more) RCA inputs for use? Any comments, suggestions or advice gladly received, Jeff
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: General advice sought...
Wiggster: Hi Guys, I have recently purchased a BeoCenter2400-2, with BeoGram 2400, a pair of S50 speakers, all housed in a lovely MC40 Cabinet. As it was an ebay purchase, and therefore sold as seen, there are a few minor niggles that I would like to ask some advice on. I have had a few different B&o systems in the past, all with their quirks, but would like to restore this one to it's former glory. 1. The right hand side of the volume display is not visible, as well as the displays for bass/treble etc - are these just blown bulbs, and if so, what are the recommended replacements? 2. One of the bass speaker cones is worn through, and although it plays OK, would be good to get a replacement- any ideas where you can get replacements? 3. I would like to ideally plug a seperate CD player, and also a lead for an ipod or digital radio into the 'Tape' input. Would ideally like a B&o CD player, but may have to wait for a while to find the right one- any suggestions? Also, is it possible to use some kind of plug that could go into the DIN socket, and give two (or more) RCA inputs for use? Any comments, suggestions or advice gladly received, Jeff
1. It is just a bulb - the 2400 is quite difficult to open up - actually it is easy to open up, more difficult to put back together! The service manual is on site and i am sure Martin can advise re bulbs. Whilst apart, it is worth replacing the red capacitors. Again Martin has a kit for this. 2. I would get the drive units repaired - Recone Lab in Huddersfield are excellent. If you want new units, Wilmslow Audio do a good range of Peerless drivers. I would however recommend repair as the better of the two options. Again replace the capacitors in the cross over. 3. There is a lead for exactly the purpose you want! It switches between Tape and CD - it is called, originally, a CD Tape adapter. I am afraid the listing on site says nothing! I did have one and it works fine. I seem to remember that it has a din plug and then a din socket and a pair of RCA sockests. It uits the Beogram CDX very well. A CD3500 would match the 2400 even better though. Welcome to Beoworld
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Hi Jeff & welcome to Beoworld 1. The bulbs have probably blown and member Dillen (Martin one of our esteemed technical advisors) can more than probably supply you with replacements. I'm sure he'll be along shortly with more detailed advice. 2. Best bet would be to refoam both woofers (the other one is probably also shot - if it is tacky then this is the case). Kits can be bought and it isn't too difficult to do if you have good basic DIY skills. If you need advice/help I can assist you here. Reconelab in Huddersfield can do the work, they are quite expensive but very good and highly recommended. 3. My personal recommendation for a B&O CD player would be a CDX which has phono outputs so will require a phono/DIN converter lead - available at any decent suppliers such as Maplins in the UK. Ipod connector leads are available from Lee at LifestyleAV. As for a way of connecting more than one item to the tape input I believe you would be best served using a CD/tape adaptor - not sure where you'd get one though but they do turn up now and again. Chris. EDIT :- Great minds and all that Peter  just beat me.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Hi Jeff, Peter was correct in that the CD/tape adaptor does have a DIN connection and RCA inputs. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Medogsfat
- Posts 4,045
Never knew about the RCA/phono inputs Craig, do you have one? Chris.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Wiggster, Welcome to Beoworld, nice system ! As already suggested, for the Beomaster 2400 (& -2) kits are available for recap'ing and for the panel lamps. The cap kit is quite comprehensive, containing about 60 components. The lamp kit contains a full set of new bulbs of correct wattage. Both kits come with instructions. The Beovox S50 speakers only have a couple of caps each but a kit is available for convienience. PM me for details. Martin
Jeff
- London
- Posts 10
Thanks for all the responses! Sounds like the jobs aren't too daunting after all! Have checked for refoaming, and will certainly try my hand at a kit first before shipping the slightly weighty speakers off to be repaired. I have a perfectly good set of JBL's that I can use until then, as I don't want to cause more problems. Just seen a CD3500 on ebay, and have put a tentative bid in- am a bit wary of old cd players though- are the lasers liable to deteriorate or break after a certain period of time? Also, more questions come before the weekend- I am going to give the whole thing a thorough clean, after the usual warm lighly soapy water treatment, is there anything you would recommend for cleaning up the aluminum? Thanks again, and am looking forward to cultivating a healthy obsession with this system! Cheers Jeff
Medogsfat
- Posts 4,045
I wouldn't worry too much about the laser on the CD3500. To all intents and purposes it is identical to the CD4500 but can be bought much cheaper due to the matt grey finish as opposed to polished aluminium panels - I have never heard of one of these going wrong. As it is a later generation to the CDX then I wouldn't envisage any problem for quite some time. For cleaning your brushed aluminium panel I wouldn't use anything more aggressive than Isopropyl alcohol. Don't be tempted to use methylated spirits as this will affect the perspex panels if you encroach onto them, nor any abrasive metal cleaners such as brasso etc.... Soapy water will probably do the job well enough any way  Chris.
Craig
- Posts 4,855
Medogsfat:Never knew about the RCA/phono inputs Craig, do you have one? Chris.
Yes Chris I do have one. Due to the fact that my BS3000 only has 1 Aux connection and I need 2. So I have the Cable from my PC connected to the DIN and the Preamp of my Turntable connected to the Phono connections. Saying that though I ordered a Beoport from my dealer yesterday. So it I might not need it much longer. Craig
Dillen
- Posts 5,008
I'm afraid that mounting LED's won't work. Neither the discriminator lights nor the volume control will work correctly since these circuits are depending on the lamps wattage. The Beomaster may also suffer from a problem going into standby for the same reason (wrong 15V load). A lamp kit containing correct lamps are available. Foam surrounds (spiders etc.) are glued using nothing but speaker cement, a glue specifically made for this, incredibly strong and still flexible. Plastic glue hardens completely , it won't be flexible and will eventually crack, I won't recommend this. Speakers with new surrounds will always sound a bit "dead" the first 10-50 hours or so, just like factory new speakers they will have to be "worked in" before losening up. Martin
Page 1 of 1 (11 items)
