Latest post 07-30-2007 1:18 PM by stereomann. 8 replies.
Page 1 of 1 (9 items)
  • 07-20-2007 11:29 PM
    • ben73
    • Not Ranked
    • Joined on 07-21-2007
    • Perth, Western Australia
    • Posts 22
    Beocenter 7007 remote
    I have recently purchased a Beocenter 7007.  Unfortunately it has no terminal remote.  Does anyone know if remotes from other units will work with the 7007?  I have been trying to track a 7007 remote down on ebay with no luck as yet.
    Ben
  • 07-21-2007 9:28 AM In reply to
    Re: Beocenter 7007 remote
    The 7000 one will work it and I believe the 7002 and 7700 will as well.
  • 07-22-2007 2:40 AM In reply to
    • ben73
    • Not Ranked
    • Posts 22
    Thanks Peter, might also have to upgrade my membership...tape deck is not working and looks like it may need some tinkering.  I am hoping the service manual is available...?
    Ben
    Ben
  • 07-22-2007 4:08 AM In reply to
    Hate to say it but no! I do have the 7000, 7002 and 7700 though! The 7000 needs putting on which I will do today (It is a bit big so will need splitting!) The tape deck will probably be belts - very common!
  • 07-22-2007 7:55 AM In reply to
    • ben73
    • Not Ranked
    • Posts 22
    Unfortunately it may be more than belts.  The mechanism engages (and immediately disengages) but I cant hear the motors running...not sure tho, there is some noise but can't tell if its a motor...after an initial poke around i have also found a broken part from near the heads...no idea what it does but if i can get acess i can probably glue it back in.  May well need belts too.  From reading other posts it looks like Martin may be able to help with belts?  any advice about the easiest way to get into a 7007?
    Thanks.
    Really appreciate the wealth of info on this site...I should of registered months ago
    Ben
  • 07-22-2007 9:31 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Yep, belts are in stock. Mounting instructions can be included, they will also tell you how to get in there.
    I may also be able to help you if the motor has died but check fuses first.
    The little part you've found is for stabilizing the cassette tray, the Beocenter will probably work fine without it. Actually finding one with the part still in place is not very common.
  • 07-22-2007 6:50 PM In reply to
    I confirm that the terminal remote works well from the 7000 to the 7700 (I have the 7007/7700 ones). For the part broken remeber that it "contains" a little ball that could be found inside the Beo under the tapedeck (if it is not gone out). If you find it you can fix the part removing the left plastic on the opposite face of the tapedeck and locking it using a little bolt (if you are a maniac like me Embarrassed ).
    ciao ciao
     PS
    Eugenio Colazzo
  • 07-26-2007 4:16 AM In reply to
    • ben73
    • Not Ranked
    • Posts 22
    Thanks for the advice...doesn't look like the broken part does all that much so I guess I'll start be replacing the belts.
    Cheers
    Ben
  • 07-30-2007 1:18 PM In reply to
    Ben, I already posted in the "Wanted" forum that I do have a BC7700 remote.
    Please contact me If you are interested.
    It is for free (or a friendly donation to beoworld.org Smile)
    regards
    alex
