Latest post 08-04-2007 7:27 PM by Friedmett. 8 replies.
Page 1 of 1 (9 items)
  • 07-19-2007 7:38 AM
    Beovision LX 2802 N - Remote Control not working
    Hi.  On the Beovision 2802, the Beolink 1000 remote does not work.  So I bought a copy remote that was guaranteed to work with the TV without any setting up - but that does not work either!  Do you think the TV has a problem with its IR signal?
  • 07-19-2007 7:50 AM In reply to
    Re: Beovision LX 2802 N - Remote Control not working
    Can you turn it on manually on the telly?
  • 07-19-2007 8:01 AM In reply to
    Yes, I can.  I can switch it on with those little buttons at the bottom of the screen.
  • 07-19-2007 9:14 AM In reply to
    Sounds like an IR problem but before calling the service department, with the set in stand by, press:
    PICTURE 1 STORE
    on the Beolink 1000 and then see if it works.
  • 07-19-2007 10:58 AM In reply to
    Thanks, Peter. Will try it tomorrow, and let you know.  Best wishes, Julie.
  • 07-19-2007 11:11 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Welcome to the forum Julie! Big Smile
    Andy T.
    Poor me, never win owt!
  • 08-04-2007 5:22 AM In reply to
    Thanks.  I think the Beolink is definitely dead - nothing works. I bought a copy remote, which  works the basic functions (like on/off, volume, etc), but I can't seem to change things like brightness/contrast, or get teletext, or any kind of set-up menu.  Can you help?   Julie.
  • 08-04-2007 8:50 AM In reply to
    This reminds me of getting my LX5500.
    I could not get the Beolink 1000 to work at all. I checked the batteries which were all fully loaded. The B&O dealer is only a 5-10 minutes walk so I went and got it fixed. He installed a new print board and it has been working ever since.
  • 08-04-2007 7:27 PM In reply to
    You can also try something else. I got a Video Terminal before my Beolink 1000 for use with my L2800.
    The seller demonstrated the Beovision with a Beolink 1000 but gave me the V -Terminal to use.
    It needed batteries but it did not work either. I took it apart and tried to touch the printboard. That worked. Put it back together and it worked with no problem. Got a new rubberpad as it had several numbers ripped from use.
    Be carefull when open the remote as there is 2 wires going to the batteries. If they get loose you need to solder them back on.
