Latest post 07-23-2007 7:24 AM by Dave. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • 07-17-2007 3:44 PM
    • Tibor
    • Not Ranked
    • Joined on 04-16-2007
    • Budapest, Hungary
    • Posts 36
    BeoLab 3500 - is it two-way remote ready ?
    Is it possible to use the BeoLab 3500 with BeoLink 5000 or 7000 remote controllers two way ?
    Next step: BV7-40 or BS3 with projector ?
  • 07-17-2007 3:48 PM In reply to
    Re: BeoLab 3500 - is it two-way remote ready ?
    As far as I know the 3500 is one way only.
    Regards Graham
  • 07-17-2007 4:30 PM In reply to
    • Tibor
    • Not Ranked
    • Budapest, Hungary
    • Posts 36
    According to this article http://www.beoworld.org/article_view.asp?id=63 the BeoLab 3500 is the only product still produced and able for two way communication...
  • 07-17-2007 5:38 PM In reply to
    I don't understand that quote since the 3500 does not have an IR emitter according to the circuit diagram!
    Regards Graham
  • 07-17-2007 6:06 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Could it mean that it is the only BeoLab Loudspeaker available with 2-way Masterlink communication?
    I didn't write that.. honest!  I'm happy to change it.
    Lee
  • 07-17-2007 6:20 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    I think it may have been read in the wrong pretext/context.
    When describing some of the two way systems, it also mentions the speaker displays.
    This is the thing that BL3500 is the last legacy of.
    I think.
    Andy T.
    Poor me, never win owt!
  • 07-17-2007 6:24 PM In reply to
    To LEE
    All ML products has two-way data Cool But not two-way audio distribution Whistle
  • 07-17-2007 9:07 PM In reply to
    Dear All:
    What is the benefit of two-way communication with the remote?  What is it?
    thnx
    Dario
    When I hear music, I fear no danger. I see no foe... Thoreau
  • 07-18-2007 3:36 AM In reply to
    darioazul:
    Dear All:
    thnx
    Dario
    That is a very good question Dario. I've heard colleagues on this forum rave on about two way communication and I still don't see a worthwhile benefit!
    C'mon guys, sell it to me!!Confused
    Regards Graham
  • 07-18-2007 3:43 AM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    joeyboygolf:
    darioazul:
    Dear All:
    thnx
    Dario
    Principle of two way is excellent and genious. One way remotes are like command and control without control at all. Following this one way remotes are really remote commanders not controllers. With two way remotes you can check what the system is doing. Especially in programming this is  nice.  Two way  facilitates user interface remotely from the actual device.
  • 07-18-2007 3:59 AM In reply to
    Putting aside the technical merits of two way remotes, surely the reason for all this discussion is because many users previously had a facility they liked and it was taken away without any apparent good reason from a users viewpoint.
    So, most technically focused B&O customers appear to like this facility, but what percentage of total B&O users actually agree ?
    When most users press a button on their remote, they expect it to perform its function without having to check the feedback display. When for example I adjust the volume on my 6500 MCL it displays the volume increasing, but I can clearly hear it, so whats the need ?
    So, in my view there is no need for two way remotes, its just that a lot of users like it, but I would suggest we are in the minority.
    Regards Keith....
  • 07-18-2007 4:05 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    I regularly use my Beo4 and WISH SO MUCH that the screen would tell me what number the volume is at, where in the menu i am, etc, without me having to get up from my comfortable chair, walk up to the main unit, and squint into the display.
    I used to have an av reciever with 2 way remote operation, but it was terrible to use as i had to really aim it at the unit. Whereas B&O 2 way really makes things easy, due to not having to point the remote.
    I wish B&O kept 2-way as an option with their equipment today! Sad
  • 07-18-2007 4:18 AM In reply to
    philipsmz333:
    Tell me why I would want to know what the volume is set at? I use my ears. Now you may think this is weird or something but I can tell you that when SWMBO says it's too loud, it's too loud! Quoting a volume setting number is no defence!!
    Regards Graham
  • 07-18-2007 5:01 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Agreed! I see two-way communication as more of a gadget than a real benefit, although with a system as advanced as the 7000, it may be a benefit, with being able to control lights and advanced timers etc...
     Weekly top artists:
  • 07-18-2007 5:10 AM In reply to
    • Kevin
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Have to say that I think in a link room situation the two way remote is very usefull.
    I have a link system in my bedroom. I have the MCP5500 there which means if I change radio stations skip cd tracks etc I can see what is happening on it´s display, which without it I´d just be guessing.
    It also means I can set the timer function and have it confirmed.
    BTW the MX3500 is shown as being two way ready does that mean it´s just a case of setting the options to two way?
  • 07-18-2007 5:14 AM In reply to
    • Mico
    • Finland
    • Posts 136
    With a system like BS3 controlling practically everything imaginable I would like to have two way remote to see what is happening. Now I need to power up the plasma display to change anything except volume.
  • 07-20-2007 6:18 AM In reply to
    • Tibor
    • Not Ranked
    • Budapest, Hungary
    • Posts 36
    This is what for I would like to use a Beolink 7000 - to have the information in the link room from the audio master in my hands.
    I have a BeoLab 3500 in the link bedroom, which displays the information, but without glasses I can not see it...
  • 07-20-2007 6:56 AM In reply to
    I think your only solution is laser eye surgery!
    Regards Graham
  • 07-20-2007 9:34 AM In reply to
    • Alex
    • Posts 2,990
    Laser eye surgery corrects issues with the retina, glasses merely re-focus the light when presbyopia becomes an issue (or the lens focuses incorrectly for some other reason).
     Weekly top artists:
  • 07-20-2007 11:31 AM In reply to
    I think that's bollocks Alex but I'm willing to be corrected, laser or otherwise.Geeked
    Regards Graham
  • 07-20-2007 2:02 PM In reply to
    • Doc
    • Top 150 Contributor
    • Posts 585
    You can also correct the conjunctiva to refocus, like with glasses or lenses.
  • 07-21-2007 11:36 PM In reply to
    • Dave
    • Posts 2,328
    Alex is 100% correct, joeyboygolf.
  • 07-22-2007 4:11 AM In reply to
    David:
    I'm not medically qualified but I could swear this talks about re-shaping the cornea to re focus the light on the retina
    http://www.opticalexpress.com/uk/the_laser_clinic/the_procedure/673
    or should I get new glasses?
    Regards Graham
  • 07-22-2007 11:34 AM In reply to
    • ridax
    • Not Ranked
    • Posts 44
    I don't really know why the subject turned into laser eye surgery and I don't know if the language thermonology is some trick, but a very common laser surgery to correct eye sight, is done to the cornea, and done in such a way that the cornea bends the rays in another fashion than before (the cornea is responsible for the most bending of the rays).
    I have just done it, and it has certainly nothing to do with the retina.
  • 07-23-2007 4:35 AM In reply to
    • Dave
    • Posts 2,328
    joeyboygolf:
    David:
    http://www.opticalexpress.com/uk/the_laser_clinic/the_procedure/673or should I get new glasses?
    Yes, lol as you have posted, it helps to re focus light through the cornea onto the retina. The retina isn't altered by the surgery - What the retina recieves is affected. What, in Alex's post is wrong? Maybe it's the wording, or are you trying to pick an argument joeyboygolf?
