Latest post 02-29-2012 9:34 AM by a2bur. 4 replies.
Page 1 of 1 (5 items)
  • 02-29-2012 2:21 AM
    • BeoIce
    • Top 200 Contributor
    • Joined on 03-27-2007
    • Recklinghausen, Germany
    • Posts 281
    One IR-Eye for two devices - possible ?
    Hi all,
    as I have two devices which need an IR-Eye I thought about if it's possible to use one IR-Eye with a y-splitter.
    One device which should be controlled is a Lintronic -238 box and the other is my diy Beomedia. The Beomedia needs an IR-Eye as I don't have a B&O video master.
    I think someone asked this before here on the forum, but I couldn't find the answer if it's possible or not.
    Can you help ?
    Regards
    BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
    Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
  • 02-29-2012 2:35 AM In reply to
    • Silou
    • Top 500 Contributor
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Re: One IR-Eye for two devices - possible ?
    Yes you can
  • 02-29-2012 5:20 AM In reply to
    Same topic , I have often wondered if it can be split again so you have three , how many times can you do this ? Suppose it depends how powerful the feed is , obviously all fire at the same time but only the targeted device understands the flash ?
    Richard
    Hmm
  • 02-29-2012 7:56 AM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    IF you have two boxes firing at the same time, no device will recognize the command. You will need to use timer control to have one command beeing fired after the other.
    hfat
  • 02-29-2012 9:34 AM In reply to
    Think I misunderstood the question , I was talking about ir. blasters .
    Richard
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
