hi, Nowadays I'm really into the programming my beo5.
But the problem came out.
I can't turn on the Tvix HD CAFE by my 6500 XML FILE or PUC controll installed by my dealer.
the PUC that I have can only turn off and do other normal controls .. :(
I heard somewhere that Tvix 6600 or S1 's remote signal is similar to my HD CAFE's
Is there any way I can get the 6600 or S1 's XML file on the web?
Thank you all :)
