Latest post 02-28-2012 8:45 PM by jjjaw. 2 replies.
Page 1 of 1 (3 items)
  • 02-27-2012 8:13 PM
    • jjjaw
    • Not Ranked
    • Joined on 12-03-2008
    • Posts 10
    The Tvix XML..
    hi, Nowadays I'm really into the programming my beo5.
    But the problem came out.
    I can't turn on the Tvix HD CAFE by my 6500 XML FILE or PUC controll installed by my dealer.
    the PUC that I have can only turn off and do other normal controls .. :(
    I heard somewhere that Tvix 6600 or S1 's  remote signal is similar to my HD CAFE's
    Is there any way I can get the 6600 or S1 's  XML file on the web?
    Thank you all :)
  • 02-28-2012 5:31 AM In reply to
    Re: The Tvix XML..
    You can download CT 5.12 where the next files are embedded:
    TViX_STB_HdN1.xml
    TViX_STB_M6500A_V02,00b.xml
    TViX_STB_M6600_V02,00a.xml
    Henk
  • 02-28-2012 8:45 PM In reply to
    • jjjaw
    • Not Ranked
    • Posts 10
    Re: The Tvix XML..
     thank you. I'm trying to figure it out.
    But this is PUC source, Is that mean that I have to get new PUC installation by my dealer?
