I have to say I dont consider 3D a priority in AV, but if someone loves 3D hey go for it.
I was going to pick up a 2nd hand BS3, as 6K is exorbitant, but 3K is closer to a reasonable cost. With exception of sub 1K Hi Fi gear, I dont think I've bought many things new, ever. I just cant fiscally justify the crushing depreciation. Mind you, this mindset works to your advantage when you can pick up a good E39 BMW M5 for sub $25k, so the driver in me gives a nod of approval.
I do view B&O gear as a buy and hold proposition. Sure there is more stuff out there that probably has an edge in some areas, but I'd see B&O as a modern classic which in my eyes delivers technically , aurally and visually as well. I've never forgotten first hearing my parents Beocenter 7007 system and how clean it ( still ) sounds, and I think that hooked me after hearing other "hi fi" systems and the B&O was just *clean* and I thought - yes, I want one of those.
I have a technical background, so running cables and wiring the house for AV is fairly easy for me, so a BS3 appeals in conceptual terms as well, for the level of integration I'm looking at trying to acheive.
I guess some of the questions I had was did anyone experience the BS3's dying, were there known bugs that can be fixed with software upgrades, do people consider it a worthy AV engine beyond the fact that it wears a B&O badge, are there issues with linking it to non B&O sources? FWIW - I am not wanting total end to end control from a single point like the BS3, if i have to start and stop my blu ray playewr from a separate remote its definately not the end of the world for me.
Any thoughts welcome ;-)
