1st March February 2012
Latest post 02-22-2012 5:10 AM by Chris. 11 replies.
02-19-2012 12:09 PM
Chris
- Joined on 05-09-2010
- Last of the Summer Wine Country, Yorkshire, UK
- Posts 195
Beosound 8 Issues with Beo5
I have configured my Beo5 to work with my Beosound 8 using the official software from Version 4.11
Has anyone had issues controlling a Beosound 8 with this? Mine doesn't work at all - No Play/Pause, Previous or Next and the wheel will not control the volume.
Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
hfat
- Joined on 05-18-2010
- Austria
- Posts 176
Re: Beosound 8 Issues with Beo5
Did you option program your beosound 8?
Have a look at the faq section of B&O web site.
hfat
Chris
- Posts 195
What do you mean by Option program? I just selected Beosound 8 in the config software and it doesnt work. I'll have a look at the FAQs
Chris
- Posts 195
Still no wiser - I have pressed 'Dock' and pressed everything but will still not work with my Beosound8.
hfat
- Austria
- Posts 176
B&O Products have different options to react when receiving IR signals. These are V.Opt for video products, A.Opt for audio products and L.Opt for link room products. These Options are from 0 to 6. Option programming is done with Beo4 or Beo5/6. Usually when you have only one B&O product in a room, you set Option 1. Factory setting for Beosound 8 is 5, so this could be your problem.
hfat
hfat
- Austria
- Posts 176
OK, I just read your latest post. So let's try the following (from the FAQ), asuming you have only a Beo5 at hand and no Beo4.
Option programming with Beo5/Beo6:
- While holding the • button, press the centre button to bring up the SETUP menu on Beo5/Beo6.
- Let go of both buttons.
- Press ‘Option Pgm’ to bring up the Option Programming display on Beo5/Beo6.
- Press the button that matches the zone in which the audio system is placed, for example, ‘Audio Area
Chris
- Posts 195
Ok the area is called lounge, what's next?
hfat
- Austria
- Posts 176
After completing this procedure, the beosound 8 should respond to your beo5
You should try now
Hfat
hfat
- Austria
- Posts 176
what about a feedback?
Did it work?
hfat
Chris
- Posts 195
hfat,
I have done that procudure above.
Into setup, opt programming, then pressed 'lounge' - the area where DOCK is, and it "clicked"but didnt do anything and still does not work.
hfat
- Austria
- Posts 176
I've sent you a PM.
hfat
Chris
- Posts 195
Thanks again for all the help.
Page 1 of 1 (12 items)
