Latest post 02-22-2012 5:10 AM by Chris. 11 replies.
Page 1 of 1 (12 items)
  • 02-19-2012 12:09 PM
    • Chris
    • Top 500 Contributor
    • Joined on 05-09-2010
    • Last of the Summer Wine Country, Yorkshire, UK
    • Posts 195
    • Gold Member
    Beosound 8 Issues with Beo5
    I have configured my Beo5 to work with my Beosound 8 using the official software from Version 4.11
    Has anyone had issues controlling a Beosound 8 with this? Mine doesn't work at all - No Play/Pause, Previous or Next and the wheel will not control the volume.
    Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
  • 02-19-2012 1:59 PM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    Re: Beosound 8 Issues with Beo5
    Did you option program your beosound 8?
    Have a look at the faq section of B&O web site.
    hfat
  • 02-19-2012 2:04 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    What do you mean by Option program? I just selected Beosound 8 in the config software and it doesnt work. I'll have a look at the FAQs
  • 02-19-2012 2:10 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Still no wiser - I have pressed 'Dock' and pressed everything but will still not work with my Beosound8.
  • 02-19-2012 2:17 PM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    B&O Products have different options to react when receiving IR signals. These are V.Opt for video products, A.Opt for audio products and L.Opt for link room products. These Options are from 0 to 6. Option programming is done with Beo4 or Beo5/6. Usually when you have only one B&O product in a room, you set Option 1. Factory setting for Beosound 8 is 5, so this could be your problem.
    hfat
  • 02-19-2012 2:27 PM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    OK, I just read your latest post. So let's try the following (from the FAQ), asuming you have only a Beo5 at hand and no Beo4.
    Option programming with Beo5/Beo6:
    • While holding the • button, press the centre button to bring up the SETUP menu on Beo5/Beo6.
    • Let go of both buttons.
    • Press ‘Option Pgm’ to bring up the Option Programming display on Beo5/Beo6.
    • Press the button that matches the zone in which the audio system is placed, for example, ‘Audio Area
  • 02-19-2012 3:36 PM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Ok the area is called lounge, what's next?
  • 02-19-2012 3:44 PM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    After completing this procedure, the beosound 8 should respond to your beo5
    You should try now
    Hfat
  • 02-21-2012 12:52 AM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    what about a feedback?
    Did it work?
    hfat
  • 02-21-2012 9:04 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    hfat,
    I have done that procudure above.
    Into setup, opt programming, then pressed 'lounge' - the area where DOCK is, and it "clicked"but didnt do anything and still does not work.
  • 02-21-2012 9:57 AM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    I've sent you a PM.
    hfat
  • 02-22-2012 5:10 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Thanks again for all the help.
