Latest post 02-27-2012 1:10 PM by onrampsrv. 1 replies.
Page 1 of 1 (2 items)
  • 02-18-2012 12:09 PM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    Beogram 8000 Cueing issues following cap replacement
    Hi
    ive used Martins great kit and replaced all the caps as per instructions. The only issue now appears on cueing the arm. Pressing play moves the arm to the correct position but it wont lower. It lowers if you move it on manually a few mm withe the << key and works perfectly??
    Any ideas?
    Andy
  • 02-27-2012 1:10 PM In reply to
    Re: Beogram 8000 Cueing issues following cap replacement
    I'm working on refurbishing an 8002 and have the same problem.  Waiting to get a cap kit from Martin and hope this will solve these problems.  How many caps did you replace?  I have already reworked almost all of the PCB connection.  I just finished a CD50 yesterday.
    I have a great Beomaster 5000, Beogram CD50, Beocord 5000, Beogram 8002
