Latest post 02-27-2012 12:13 PM by Orava. 5 replies.
Page 1 of 1 (6 items)
  • 02-18-2012 10:43 AM
    • Orava
    • Not Ranked
    • Joined on 10-25-2009
    • Finland
    • Posts 28
    Penta midrange refoam
    Hi
    They are aviable foam and rubber surrondings for Pentas midrange speakers.
    Do anyone have any experiences about them, is eiher of them better than other?
    Original is foam but if replaced with rubber, it will last longer but does it affect the sound of speakers?
    Anyone have rerubber them?
    Filed under:
  • 02-18-2012 1:02 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: Penta midrange refoam
    I wasn't sure myself so ordered foam replacements. Haven't fitted them yet as with all my own gear I never seem to find the time to finish lol!
    I would think it would matter less with mid drivers tbh, and there is a thread somewhere where a user was able to directly compare and not notice any difference!
    Olly.
  • 02-18-2012 2:58 PM In reply to
    I have heard from someone who had the surrounds of his CX100's replaced by rubber surrounds. The did not sound like before, the sounded worse. In case of MS150's I have heard that placing rubber surrounds improved the bass. So it can go both ways......
  • 02-18-2012 5:31 PM In reply to
    Just finished 8 and foam has been used!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 02-19-2012 12:15 PM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Blackrix:
    I have refoamed cx50 with rubber surrounds in comparing to a pair of c2300 (C40) which I refoamed with foam surrounds the bass of the cx50 are deeper and more powerfull.
    The Cx100's I refoamed with foam surrounds, because of the rubber ones the clue surface is smaller than the foam ones. The rubber surrounds i got were smaller
  • 02-27-2012 12:13 PM In reply to
    • Orava
    • Not Ranked
    • Finland
    • Posts 28
    Ok, I guess it's safer to go with foam. Afterall it's midrange and foam is more flexible(?) than rubber, and refoaming happens once in 20 years, I hope.
    Thanks everyone for opinion :)
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
