Actually it will but you have to leave the CD in the machine for almost a day, it will then play that CD perfectly. Turning it off and leaving it when you next press play it works perfectly again, all the functions work. However if you open the drawer to put another CD in it will attempt to play, showing the number off tracks sometimes but will then fail, making an odd hissing noise. Leave it for a day, return and it will play straight off!
Any idea on what's wrong? I have change the capacitor that is mentioned a lot, but this seems to have made no difference!
On another subject, I have found that there is an iPod docile for this system that was made but I can't seems to be no way to buy it or the parts to build it.. Any ideas on what has happens to it? As I for one would love to have one!
