Latest post 02-20-2012 6:25 AM by Dean. 4 replies.
Page 1 of 1 (5 items)
  • 02-16-2012 6:33 PM
    • Dean
    • Not Ranked
    • Joined on 09-03-2009
    • Posts 13
    BeoVision 8-40 Record to usb
    Hi I have recently purchased a bv8-40 and over the moon with it, the picture quality is excellent, however the most thing i miss is not being able to record in a simple seemless way. ie as i used to do with my old tv and I dont want to add a pvr onto the bv8
    I have noticed that the set has a usb slot, which i was wondering if you could record straigt to a usb key, that would be great. I havnt tried this but just thought i would ask if anyone has done this?
    Many thanks
  • 02-16-2012 6:52 PM In reply to
    Re: BeoVision 8-40 Record to usb
    Sorry, not possible, USB is only for update purposes.
    (It's B&O, not Samsung)
    /Räuber
  • 02-17-2012 9:56 AM In reply to
    • Dean
    • Not Ranked
    • Posts 13
    Thank you very much Raeuber, its doesnt surprise me and if only B&O would take some steps to add this funtion.
    PS I had a sony not samsung but they are probally the same inside anyhow
    Kind regards
  • 02-17-2012 10:11 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Try to find a good HDD recorder supported by the PUC of the Beovision, and hide it.
    Some times ago, I would have advised to buy a Tvix, but the DVICO company has now ceased all its activity in the TVix, so there will be no future software development (for DVB update compatibility for instance), so now I can only recommend to avoid it.
    [EDIT] : Tvix is not dead, but in search of a buyer... So it looks better for the aftersale support... Here is the official answer to this (via digitalversus)
  • 02-20-2012 6:25 AM In reply to
    • Dean
    • Not Ranked
    • Posts 13
    Thank you, I have just ordered sky hd and have to go with an external box, but I managed to pick up the beo8-40 cabinet so this will now be out of site.
    I just now have to get my beo4 & beo5 programmed
    would anyone have a mapping chart?
    Regards
