Latest post 02-14-2012 7:48 PM by Jonathan. 18 replies.
Page 1 of 1 (19 items)
  • 02-12-2012 12:17 AM
    UK sourced TVs in Australia
    Hi everyone
    Does anyone know if you can use a B&O tv originally bought in the UK...in Australia?  Am thinking of the beovison7 and 10 range.  Anyone in Oz done it?
    Thanks,
    Paul
  • 02-12-2012 7:12 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: UK sourced TVs in Australia
    I've been shipping TV's to Australia for 8 years now with not one reported problem if that helps!
    Most of the modern TV's have everything pre-built into them anyway, so tuner changes can be made in the service menu.
    Lee
    Smile
  • 02-12-2012 11:24 AM In reply to
    8 years?  So LSAV started shipping goods in 2004?
  • 02-12-2012 11:31 AM In reply to
    So LifestyleAV now claim to have been in operation from February 2004?
  • 02-12-2012 12:00 PM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    KingOfSnake:
    Here we go!!! Been on holiday??
  • 02-12-2012 12:47 PM In reply to
    KingOfSnake:
    Hi KOS. Sorry to see that your life still sucks. Hope you get over it soon! Yes -  thumbs up
    -Dimitris
  • 02-12-2012 12:56 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    DrDimitris:
    KingOfSnake:
    Very well put Yes -  thumbs up
  • 02-12-2012 1:08 PM In reply to
    JC:
    DrDimitris:
    KingOfSnake:
    +1
  • 02-12-2012 1:16 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Ermm.. I didn't actually mention LifeStyle AV.  I actually make an effort not to. Hmm
    I had quite a few bits of B&O in my home before i even thought of launching a business.  In this time, when i wanted to sell my old MX's and the like, i advertised them on eBay - and shipped a few to Australia.  I had no problems at all, even back then.
    As mentioned, aside from voltage issues (which come into play when shipping to the US and Japan in the main, who are 110v as opposed to much of the rest of the world who operate on 220-240v) there isn't much you can't change in the service menu of the modern sets.
    However, I will now read and re-read all posts i make in case any dates of any kind could be misconstrued. I wholeheartedly apologise for any distress this may have caused to anyone reading my previous post..
    Lee
    Smile
  • 02-12-2012 1:20 PM In reply to
    KingOfSnake:
    LOWER THAN A SNAKES BELLY!!!
  • 02-12-2012 1:26 PM In reply to
    • JC
    • Yorkshire / UK
    • Posts 621
    Now you have jumped in with two big feet again!! By all means make the necessary apology!!
  • 02-12-2012 4:49 PM In reply to
    I actually don't have a problem with Lee mentioning his business in threads.
    After all, he is a paying sponsor of the site.
    The same goes with Steve at Sounds Heavenly, STB, Hygge Living and the Beo5 Programming Service.
    They all pay their way! Maybe the other B&O resellers who feel like they're getting a bad deal might like to sponsor as well??
    My B&O: 2009 Catalogue and Pricelist
  • 02-12-2012 5:05 PM In reply to
    Jonathan:
    Don't even go there!!!!!
    Regards Graham
  • 02-12-2012 5:11 PM In reply to
    Ok that's sounding good...so I buy in the UK from you say, it duly arrives in Oz...how do it know what to change in the menu?
    Also what about digital tuners?  Are they built in or would I need to use a separate STB?  Am thinking of the BV10-40" or possibly the 32".
    If it all gets too confusing to set up do you think a local tv/aerial tech person would be able to do it.  Are B&O any different in that regard?
    Thanks everyone,
    Paul
  • 02-12-2012 9:57 PM In reply to
    Hi Paul,
    where are you in Australia?
  • 02-13-2012 3:24 AM In reply to
    Hi all,
    I am thinking about buying a pre-owned Beosystem3 from UK to be used in Australia.  I wonder if there would be any issues.
    From what I could gather, in this case a beosystem 3 - Australia and New Zealand specific model is type 9603 and UK specific is Type 9601.
    The Active CTV system in
    Type 9601 is 'I' only
    Type 9603 is 'B/G'
    Can anyone shed light on what active CTV system does and how does the alphabetical designation differ between countries?
    Matt
  • 02-13-2012 3:33 AM In reply to
    BangOFan:
    All is revealed here http://en.wikipedia.org/wiki/Broadcast_television_systems
    but not necessarily explained ... it certainly did my head in
    and helps explain why Steve Jobs describe the television industry was "Balkanised"
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 02-14-2012 4:10 AM In reply to
    Hi Jonathan
    I'm in Sydney.  It looks like it should work fine from what I've read above.  Have you done this yourself?
  • 02-14-2012 7:48 PM In reply to
    Hi Paul,
    I haven't, but the UK and Australia both use Pal so it should work fine!
    Best of luck, go for it I say Yes -  thumbs up
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
