Eric Philips: B&O in Denmark gave me that BS2 to take to the North Pole in 2002.
Its big advantage (at that time) was no moving parts to freeze up ! I probably still have that article in my B&O collection ! I still have my BS2 even though I never use it ... certainly would never offload it, too many good memories.
Eric Philips:4. Link Player. Gggrrr! I'ver had it on my iPhone and iPad and Macbook for over a year but they never speak to each other via my Cisco wireless router, they constantly search for a signal, despite the phone and iPad being connected to the wireless network OK.
I have never had that level of problem ! Do you have a very complicated home network ? Is it worth considering replacing the CISCO - or perhaps borrowing something from someone and trialing that ?
Eric Philips:3. I can't simultaneously run analog and HDMI audio from the Mini, right? Once I plug the cable into the headphone socket I disable HDMI (or is it vice versa). If so, then I can't seamlessly jump from N.Music to Front Row.
Correct, that "feechure" was introduced by Apple with an LION "upgrade" in the fourth quarter - you may have seen my post warning about the consequences of the upgrade, and my latest update saying that the upgrade to the upgrade has not improved the situation
Eric Philips:2. Should I connect the BV10 and control panel of BC2 with an optical cable?
I don't know :-) not my area of experience / knowledge
Eric Philips:1. N.Music and N.Radio are working fine but of course, as you suggest, I can't use the BV as a monitor to find music more easily.
I find the iPad's Apple REMOTE App is the best control for searching and organising playlists
Not sure if LinkPlayer's broadcasting of the song meta data would show up on the BC2, they do on my BS4 which provides a level of monitoring, but I prefer the iPad approach
Eric Philips:In the interim I did what I had done earlier and simply connected the Mini and Beoport with a 3.5mm audio cable and hey presto, sound!
This bit I don't understand ... except you must have had the BeoPort connected to the MasterLink already ... right ?
Eric Philips:Thanks for the advice
My pleasure.
I must admit that I am no longer certain as the best way to proceed during this period of flux with B&O, Apple and now even Google starting up in the home entertainment space.
I find I am using my Apple TV more and more, and relying on WiFi more and more, and as a consequence my LinkPlayer usage is dropping off as I move towards Airplaying everything everywhere.
It may be that the ATV is the better solution for you and that Airplay from iTunes to the ATV / BV10 and simultaneously send the iTunes analogue signal via LinkPlayer / BeoPort / ML / Link Rooms.
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
