Latest post 01-31-2012 3:49 PM by w5bno123. 5 replies.
Page 1 of 1 (6 items)
  • 01-29-2012 9:25 PM
    • andrew
    • Not Ranked
    • Joined on 10-01-2011
    • Posts 6
    Condensation inside the LCD panel of BV7-40
    Anybody experience in the above?
  • 01-30-2012 7:54 AM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Re: Condensation inside the LCD panel of BV7-40
    Yes.
    It is most likely the seal between the chassis and glass. There were some that were faulty - or deteriorated prematurely. Contact you local dealer, if under warranty it's a quick fix. Other wise it's not an expensive job.
  • 01-30-2012 4:52 PM In reply to
    Hi Andrew this isn't a fault but change in atmospheric conditions. We often see this on sets delivered to the store at this time of year when it's cold! If they go straight on the shopfloor and we power them up the condensation appears. The thing to do is put the TV in a warmer environment, then turn on the set on. Use a couple of plastic levers to prise the glass AR screen slightly forward and after 5 minutes it disappears, instead of the plastic levers do it by hand.
  • 01-31-2012 8:03 AM In reply to
    • Dude1
    • London
    • Posts 189
    with the greatest respect, I probably would have a qualified technician sort this - than risk fracturing the glass prying it in any way.
  • 01-31-2012 12:21 PM In reply to
    • valve1
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Dude1:
    I am in 100% agreement with Dude1 on  this, this gear is toooo expensive to be prying.
  • 01-31-2012 3:49 PM In reply to
    You will find that the top edge of the glass is spring loaded and will pull forward without much force. Yes you are right the products cost a lot of money and you should call your dealer to sort it out for you!
